Dear ESP'ers,
I'm using a rather simple setup with the following components.
-Wemos D1 Mini
-DHT22
-2 Channel Relay
Now i got the relay, the display and the Sensor to work fine, except i want the reading visable on the LCD as told on (http://www.esp8266.nu/index.php/LCDDisplay).
I can get the IP visable and any other text, except for the DHT readings.
I have tried the value: H: [DHT#Humidity]% T: [DHT#Temperature] C, where The value names are the same as those from the DHT sensor.
Can anyone tell me what i'm doing wrong?
DHT reading on LCD
DHT reading on LCD
- Naamloos2.jpg (61.55 KiB) Viewed 9981 times
- Naamloos.jpg (61.19 KiB) Viewed 9981 times
Re: DHT reading on LCD
I think you need to have the same task name. Try using 'Temp/hum' like you have it named.
After your post i tried this, but it didn't change anyting.
Do you, or anyone else have a working setup like this, where i can take over the value's?
I don't know what to change from here anymore.
I think you have to call your sensor "DHT", since you referenced so in the display line
I was going to say the same thing. Use a simple name. Maybe the slash is messing it up.
It works now!!
Thanx People!!
Solution: never use "/"
Thanx People!!
