I was not sure about this one if it's using rf 433mhz and finaly it seems to be the case. Will be really nice if it can be decoded by Rflink.
Basically this sensor sends 3 times the same data, temp, hygro and battery like this:
Acurite tower sensor Ch A: 7.4 C 45.3 F 51 % RH (from an rtl_SDR)
20;A1;DEBUG;Pulses=366;Pulses(uSec)=570,510,510,510,510,510,510,510,300,1
20,300,120,300,120,120,300,120,300,300,120,300,120,120,300,300,120,120,30
0,300,120,120,300,300,120,120,300,300,120,120,300,120,300,300,120,120,300
,120,300,120,300,300,120,120,300,120,300,120,30
0,120,300,300,120,300,120,120,300,120,300,300,120,300,120,300,120,120,300
,120,300,120,300,300,120,120,300,120,300,120,300,300,120,120,300,300,120,
300,120,120,300,120,300,300,120,120,300,120,300,300,120,120,300,120,300,1
20,300,120,300,120,300,300,120,120,2100,510,510,510,510,510,510,510,510,3
00,120,300,120,300,120,120,300,120,300,300,120,300,120,120,300,300,120,12
0,300,300,120,120,300,300,120,120,300,300,120,120,300,120,300,300,120,120
,300,120,300,120,300,300,120,120,300,120,300,120,300,120,300,300,120,300,
120,120,300,120,300,300,120,300,120,300,120,120,300,120,300,120,300,300,1
20,120,300,120,300,120,300,300,120,120,300,300,120,300,120,120,300,120,30
0,300,120,120,300,120,300,300,120,120,300,120,300,120,300,120,300,120,300
,300,120,120,2100,510,510,510,510,510,510,510,510,300,120,300,120,300,120
,120,300,120,300,300,120,300,120,120,300,300,120,120,300,300,120,120,300,
300,120,120,300,300,120,120,300,120,300,300,120,120,300,120,300,120,300,3
00,120,120,300,120,300,120,300,120,300,300,120,300,120,120,300,120,300,30
0,120,300,120,300,120,120,300,120,300,120,300,300,120,120,300,120,300,120
,300,300,120,120,300,300,120,300,120,120,300,120,300,300,120,120,300,120,
300,330,120,120,300,120,300,120,300
,120,300,120,300,300,120,120,6990;
Not sure but I think it's only 1 frame eaxh time.
Solved: Acurite temp hygro sensor 609TXC
Re: Acurite temp hygro sensor 609TXC
Will be supported soon..
Great... Thanks
Re: Solved: Acurite temp hygro sensor 609TXC
Should be working with Firmware revision 42
Users browsing this forum: No registered users and 44 guests
