Is it possible to get IP address after boot (via serial monitor)?
Is there an easy way to get the ip address when it boot?
Re: Is it possible to get IP address after boot (via serial monitor)?
Are you connected via Serial Interface ?
Just type "Settings" with capital S, then you´ll see the IP Address
Thanks - I didn't know that "trick". Is it more commands available?
Whats the difference between Settings and settings? I see the same result.Are you connected via Serial Interface ?
I connected via serial Interface. I wrote "Settings" command in terminal but nothing happened.
How does it work?
How does it work?
You need to make sure your terminal program sends both <CR> and <LF> ("DOS newline").spaceguard wrote:I connected via serial Interface. I wrote "Settings" command in terminal but nothing happened.
This has bitten me in the past, since minicom (which I use on Mac and Linux only sends unix style newlines)
- Jan
Jan Chrillesen, Denmark
