TM1637 support
MegaBOOBLIK
TM1637 support
#1 Post by MegaBOOBLIK » 02 Jun 2016, 10:01
Hi!
ESPEasy it's very great softvare!
But wey dont have support TM1637.
I'`m made very simle clock and want some more, termal sensor with MQTT.
Does some one made something with TM1637 display?
Based on this post http://samopal.pro/esp8266-4/
My code
#include "TM1637.h"
#include <ESP8266WiFi.h>
#include <WiFiUdp.h>
//CLK,DIO
TM1637 tm1637(13, 14);
char ssid[] = "XXX";
char pass[] = "YYY";
#define TIMEZONE 3
unsigned int  localPort = 2390;   // local port to listen for UDP packets
unsigned int ntp_corr = 60;        // how often make correct (min)
unsigned int ntp_count = 0;       // Correct counter
unsigned long ntp_time = 0;       // TIME
bool points   = true;                   // blinking points
IPAddress timeServerIP;
const char* ntpServerName = "time.nist.gov";
const int NTP_PACKET_SIZE = 48;
byte packetBuffer[ NTP_PACKET_SIZE];
WiFiUDP udp;
void setup()
  tm1637.init(); // CLEAR DISP
  tm1637.set(7); // DARKEST = 0, BRIGHTEST = 7
  for ( int i = 0; i < 4; i++) {
    tm1637.display(i, i);
    delay(300);
  Serial.begin(115200);
  // WiFi
  if ( !ConnectWiFi(ssid, pass) ) ESP.reset();
  // START UDP connect NTP
  udp.begin(localPort);
  while (ntp_time == 0) GetNTP();
void loop() {
  tm1637.display(0, ( ( ntp_time / 3600 ) % 24 ) / 10);
  tm1637.display(1, ( ( ntp_time / 3600 ) % 24 ) % 10);
  tm1637.display(2, ( ( ntp_time / 60 ) % 60 ) / 10);
  tm1637.display(3, ( ( ntp_time / 60 ) % 60 ) % 10);
  ntp_time++;
  ntp_count++;
  tm1637.point(points);
  points = !points;
  delay(1000);
  if ( ntp_count == ( ntp_corr * 60 ) ) GetNTP();
// WiFi
bool ConnectWiFi(const char *ssid, const char *pass) {
    WiFi.begin(ssid, pass);
    delay(5000);
    if (WiFi.status() == WL_CONNECTED) {
      Serial.print("\nWiFi connect true: ");
      Serial.print(WiFi.localIP());
      Serial.print(" / ");
      Serial.print(WiFi.subnetMask());
      Serial.print(WiFi.gatewayIP());
      Serial.print("\n");
      return true;
    tm1637.display(i, WiFi.status()); // STATUS
  Serial.println("\nConnect WiFi failed ...");
  return false;
// NTP server request
bool GetNTP(void) {
  WiFi.hostByName(ntpServerName, timeServerIP);
  Serial.println("Sending NTP packet...");
  // clear to 0
  memset(packetBuffer, 0, NTP_PACKET_SIZE);
  packetBuffer[0] = 0b11100011;   // LI, Version, Mode
  packetBuffer[1] = 0;     // Stratum, or type of clock
  packetBuffer[2] = 6;     // Polling Interval
  packetBuffer[3] = 0xEC;  // Peer Clock Precision
  packetBuffer[12]  = 49;
  packetBuffer[13]  = 0x4E;
  packetBuffer[14]  = 49;
  packetBuffer[15]  = 52;
  // NTP to 123 port
  udp.beginPacket(timeServerIP, 123);
  udp.write(packetBuffer, NTP_PACKET_SIZE);
  udp.endPacket();
  delay(3000);
  int cb = udp.parsePacket();
  if (!cb) {
    Serial.println("No packet...");
    //BAD NTP
      tm1637.display(i, 8);
      delay(100);
    delay (100);
    return false;
  else {
    // Читаем пакет в буфер
    udp.read(packetBuffer, NTP_PACKET_SIZE);
    // 4 байта начиная с 40-го сождержат таймстамп времени - число секунд
    // от 01.01.1900
    unsigned long highWord = word(packetBuffer[40], packetBuffer[41]);
    unsigned long lowWord = word(packetBuffer[42], packetBuffer[43]);
    // Конвертируем два слова в переменную long
    unsigned long secsSince1900 = highWord << 16 | lowWord;
    // Конвертируем в UNIX-таймстамп (число секунд от 01.01.1970
    const unsigned long seventyYears = 2208988800UL;
    unsigned long epoch = secsSince1900 - seventyYears;
    // Делаем поправку на местную тайм-зону
    ntp_time = epoch + TIMEZONE * 3600;
    Serial.print("Unix time = ");
    Serial.println(ntp_time);
    ntp_count = 0;
  return true;
NietGiftig
Re: TM1637 support
#2 Post by NietGiftig » 02 Jun 2016, 12:45
MegaBOOBLIK wrote:Hi!
I'm not sure if you are in the right forum, this is for the RFLink software
But for your question : Maybe its because you are the only one using the TM1637
But you are free to make a plugin and submit it to ESPEasy software.
https://github.com/ESP8266nu/ESPEasyPluginPlayground
mili14
Re: TM1637 support
#3 Post by mili14 » 09 Jan 2017, 19:09
I found http://robotdyn.com/catalog/segment/4_d ... _segments/
is any chance for support it?
