Battery status / level
Dear people,
I have a setup with a esp-1 with a temperature sensor ds18b20. Connected with 2 aa batteries.
Is it possible to get a reading of the battery level? I use domoticz to receive the temp status.
Kind Regards,
Fabian
Kind Regards,
Fabian
Re: Battery status / level
hi Fabian,fibigod wrote:I have a setup with a esp-1 with a temperature sensor ds18b20. Connected with 2 aa batteries.
check the "Measure VCC" thread here:
http://www.esp8266.nu/forum/viewtopic.php?f=6&t=1357
Of course this is only a reading on the Vcc and gives the output in volt, this is not in any way a battery gauge to tell you 100% or 50% or 10% of battery left. But it's better than nothing, and it comes already with the R107 code, though it has to be specifically added by changing one line in the main ESP Easy source code.
See if it can help your needs.
Bye, Luca
Hi Fabian
It should be fairly easy to implement using a voltage divider and feeding the voltage to the ADC input of the ESP. I'm using an ESP-12E module and the ADC input is on pin 2. You need the voltage divider because the ADC input can only take a max of around 1V. Since you're using 3V, one option for the two resistors for the voltage divider are 4.7K and 10K. You should be able to pick other resistor values if you don't have those two on hand. 10K should be fairly common, for the other value, anything less than 4.7K should be fine. However you do not want to go too low or you will start to loose resolution. If you are not familiar, the way to connect it all up is to connect the resistors in series first ie: connect two end of the two resistors together, then connect the unconnected end of the 10K to the positive of the battery and then connect the unconnected end of the 4.7K to the negative/ground of the battery. You then connect the point where you connected the two resistors together to the ADC input. That should be it for the hardware.
For the software side, you will need to add a device and then make up a formula to calculate the real voltage. First you will need to create a new device type "analog input" and give it a name and IDX value. Once you have done that click on submit and look at the analog value in the table of devices. Use a multimeter and measure the real voltage of the battery. Take the voltage you measured with the multimeter and divide by the analog value. For example this might be 0.004571. You then go back to your analog device and enter the following formula into the "Formula Analog" box: %value%*0.004571
It should now send the correct voltage reading to Domoticz.
Good Luck!
Good Luck!
Thank you for the solutions provided.
I've used the build suggested by lucaberta and changed the vcc line in the sourcecode.
is this schematic ok ?
Hi everyone!
D1mini already have voltage divider 220KOhm/100KOhm on ADC pin.
I'm using 3.3MOhm and 1MOhm for my battery powered sensors. so this voltage divider consumes under 1 micro amp. esp8266 have very large input impedance (over 12MOhm),
To have an idea about battery percentage left and RSSI, I've add these lines in C002 (I'm using domoticz MQTT):
In EspEasy.ino:
In Webserver.ino:
In C002.ino just before
I know the code is awful, but I'm not a programmer after all.
You can adjust "(analogRead(A0) - 700)/2" according to your R1/R2 and the type of battery (lipo or 3AA) to show more correctly percentage.
This it the result:
In EspEasy.ino:
int BatteryLevel = 0;
* SETUP
if (WiFi.status() == WL_CONNECTED)
BatteryLevel = (analogRead(A0)-700)/2;
if (BatteryLevel > 100)
BatteryLevel = 100;
else if (BatteryLevel < 0)
BatteryLevel = 0;
reply += F("<TR><TD>Wifi RSSI:<TD>");
reply += WiFi.RSSI();
reply += F(" dB");
reply += F("<TR><TD>Battery:<TD>");
reply += BatteryLevel;
reply += F(" %");
char json[256];
root["RSSI"] = (WiFi.RSSI()+100)/5;
BatteryLevel = 100;
BatteryLevel = 0;
root["Battery"] = BatteryLevel;
<---------------- original code------------------------//
char json[256];
This it the result:
MQTT: Topic: domoticz/in, Message: {"idx":2,"nvalue":0,"svalue":"12.50","RSSI":8,"Battery":33}
- espbattery.jpg (34.03 KiB) Viewed 31846 times
I've tried voltage reporting, using several power supplies (3x1.5V, 2х1.2V etc)... Unfortunately when using 2x1.2V rechargeable batteries, Domoticz logically reports LOW BATTERY.
Simeonof's idea was great, but needs some update, to solve such issues....
So i upgraded his idea with:
1. Working on HTTP domoticz communication too
2. Voltage calibration index can be changed using CONFIG screen
So changes are not too big (including/alternating simeonof's code), but it's not easy to explain step by step, because small changes are fragmented file by file...
Anyway... Required changes are remarked (ADD LINE(S) BELOW / ABOVE)
ESPEasy.ino
In Webserver.ino
// ADD LINE(S) ABOVE
In _C001.ino (http requests)
In _C002
ESPEasy.ino
// ADD LINE(S) BELOW
* SETUP
struct SettingsStruct
int16_t TimeZone;
int16_t BatteryVoltageIndex;
} Settings;
// Web Interface root page
void handle_root() {
String BatteryVoltageIndex=WebServer.arg("batteryvoltageindex"); // BATTERY VOLTAGE INDEX INITIALIZATION
//****** START BATTERY LEVEL VIEW
BatteryVoltageIndex=Settings.BatteryVoltageIndex;
BatteryLevel = (analogRead(A0)- BatteryVoltageIndex.toInt())/2;
BatteryLevel = 100;
BatteryLevel = 0;
reply += F(" dB");
reply += F(" %");
//******* END BATTERY LEVEL VIEW
// Web Interface config page
void handle_config() {
String apkey = WebServer.arg("apkey");
String BatteryVoltageIndex = WebServer.arg("batteryvoltageindex"); // Battery reporting voltage index - BATTERY LEVEL = ( ANALOG INPUT VALUE - VOLTAGE INDEX) / 2
Settings.Unit = unit.toInt();
Settings.BatteryVoltageIndex = BatteryVoltageIndex.toInt(); // Battery voltage index reading
SaveSettings();
reply += F("'><TR><TD>Unit nr:<TD><input type='text' name='unit' value='");
reply += Settings.Unit;
// BATTERY VOLTAGE INDEX CELL
reply += F("'><TR><TD>Battery Index (700 for 3x1.5V batteries) :<TD><input type='text' name='batteryvoltageindex' value='");
reply += Settings.BatteryVoltageIndex;
// END OF BATTERY
reply += F("'><TR><TD>Protocol:");
boolean CPlugin_001(byte function, struct EventStruct *event, String& string)
case SENSOR_TYPE_DIMMER:
//************** START BATTERY REPORTING
int BatteryVoltageIndex=Settings.BatteryVoltageIndex;
if (BatteryVoltageIndex>0) {
BatteryLevel = (analogRead(A0)-BatteryVoltageIndex)/2;
BatteryLevel = 100;
BatteryLevel = 0;
url += F("&rssi=");
url += toString((WiFi.RSSI()+100)/5,0);
url += F("&battery=");
url += toString(BatteryLevel,0);
url += ";";
//************ END BATTERY REPORTING
url.toCharArray(log, 80);
addLog(LOG_LEVEL_DEBUG_MORE, log);
// This will send the request to the server
BatteryLevel = 100;
BatteryLevel = 0;
char json[256];
