ESP Easy sending data to my personal Software
Posted: 25 Jun 2016, 23:14
Hi guys,
I´m new with ESP and after reading a lot of things I´ve found the ESP Easy and Im interested on it. I already have a system where I use an arduino + Zigbee to send temperature, distance, voltage readings and control a DC motor with pwm, the data is sent to a software on the computer, done in C#. Now I want to use only an ESP in place of the arduino + zigbee and change the software to support it. I´m still reading about MQTT to better understand it but I´m not sure if I´m thinking in the right way.
My doubt is: Can I use the ESP Easy and instead of sending the data to domoticz, openhab... send the data to my software? or if possible send to domoticz and somehow get this data from there to feed my system. I don´t know the protocol that they use so I dont know if it is easier to use the ESP easy and adapt it to my system or start from scratch on the ESP programing using the Arduino IDE.
Thanks in advance,
Jean Soares
Thanks in advance,
Jean Soares
