Wiki update
bertrand
Wiki update
#1 Post by bertrand » 30 Jun 2016, 19:54
Hi Guys,
As I'm just beginning with ESPEasy, i'm reading the Wiki to understand how things work.
I found several points to improve:
http://www.esp8266.nu/index.php/ESPEasy
Configuration
To get you on track with the ESP Easy, we provide a tutorial to demonstrate the basics Tutorial_Domoticz_Switch For all further applications, please check their respective wiki page Applications
In fact, it should a mandatory stop, not only for Domoticz users... non Domoticz users might want to skip that essential part.
And in this page:
http://www.esp8266.nu/index.php/Tutoria ... icz_Switch
Connect the ESP Easy to your network
If you have your ESP board loaded with ESP Easy firmware, powerup the unit and an Access point named "ESP_0" should appear. Connect to this access point and browse to http://192.168.4.1. If all went well, the following screen should be shown:
Hold on a second: when I scan my wifi networks I can only see a protected ESP_0, where is the WPA key ???
Further down...
So please add in clear that the default key is "configesp"
Other than that, this project is awesome !
