Wemos D1mini + Oled Shield Display Issue
Posted: 02 Jul 2016, 02:29
by QcVictor
I have Wemos D1mini + DTH22 + Oled Shield, temp/hum sensor work great, the oled shield display just an "easy" at startup, I'm on R78. any clue what happen?
Re: Wemos D1mini + Oled Shield Display Issue
Posted: 02 Jul 2016, 02:32
by costo
Posted: 02 Jul 2016, 02:33
by QcVictor
yes for sure, missing something ?
oups, I have to put on ! http://<ESP IP address>/control?cmd=oledcmd,on
the Screen Size is 64x48 and I'm unable to display temp and humidity, do I need to setup something in the skecht for this size of screen ?
Posted: 02 Jul 2016, 23:07
by QcVictor
unable to get my temp and humidity from dht22 shield displayed, tried with H: [DHT#Humidity]% T: [DHT#Temperature] C and [Dallas#Temperature]
Posted: 03 Jul 2016, 02:09
by costo
Did you give the DHT a name in tasksettings?
It should be DHT to let the string [DHT#Temperature] display the value temperature, and for humidity the same.
Probably also you need to activate the box 'Send Data" and give IDX/Var a number >1
Posted: 03 Jul 2016, 03:34
by QcVictor
Many thanks Costo, name in task settings was missing !
Posted: 11 Jul 2016, 01:06
by QcVictor
Can I display distance from Ultrasonic Sensor - HC-SR04 ?
Posted: 19 Oct 2018, 10:09
by tipaaetaa
[DeviceName#ValueName]
