two rules questions
Posted: 12 Jul 2016, 11:44
I have built my my marquee control around an ESP-01 running ESP Easy to control the two relais using the two gpios. Things work fine and I've even created a ruleset that automatically drives the marquee to defined points - actually, drives it a defined distance (10%, 25%, 50%, 100%)
Two things I wonder:
pj
- can a rule event take a parameter? (like: event=extend&dist=10) - this would also require that there is some basic math feature (like, multiplying with 4) available
- I have found the command gpio,n,[01] to be available, would pulse also be available in rules?
pj
