Firmware reload
tsanalytics
Firmware reload
#1 Post by tsanalytics » 06 Aug 2016, 17:16
Hi There,
I made a mistake with my wifi settings and now I am unable to connect to the ESP to fix it.
When I look at the terminal output, it connects and disconnects. I thougt an easy fix would be to re flash the firmware, but that does not work as somehow it has stored the old configuration and is not clearing it. Please help
hamster
Re: Firmware reload
#2 Post by hamster » 06 Aug 2016, 18:59
have you checked if its gone into AP mode?
See if you can see the ESP_01 wifi station
connect using key 'configesp' then go to 192.168.4.1
kr0815
Re: Firmware reload
#3 Post by kr0815 » 06 Aug 2016, 21:19
when in terminal , you could type
- settings - to check your settings
- wifissid "your wifiname"
- wifikey "your wifipassword"
- save
