Hi all,
Just trying to understand how it all works. I have some watts clever power sockets, which I think are unsupported (unless after a different name).
http://www.wattsclever.com/gb/products/easy-off-sockets
What I don't understand is that when I run the debug and grab the data transmitted from the control button/s, the received data will vary from push to push from the same button, even though the socket 1 "on" button has one purpose and that is to turn on the socket. Because of this it is recognized as different products as well.
Is this an expected outcome for a non-supported device or does the different received codes indicate an issue with my RX board due to noise or such? Just trying to understand why the code would vary?
Why different codes in debug log on Watts Clever Sockets
Re: Why different codes in debug log on Watts Clever Sockets
Hard to tell without seeing the debug log..
can you mail it to frankzirrone@gmail.com or post it here
Will grab some data over the weekend and post.
This is the first button.
Watts Clever Power Sockets
Socket 1 On
This the output from several button pushes
Cheers
20;35;DEBUG;Pulses=52;Pulses(uSec)=60,1440,360,690,360,660,330,690,960,90,360,660,330,690,960,90,960,90,930,90,930,90,300,720,930,90,930,120,300,720,330,720,930,120,300,720,300,720,300,720,300,720,930,120,930,120,930,120,300,720,300,6990;
20;36;DEBUG;Pulses=50;Pulses(uSec)=360,750,270,750,270,750,900,150,270,750,270,750,870,150,900,150,870,150,870,180,270,780,870,150,870,180,240,780,240,780,870,180,240,780,240,780,240,780,240,780,870,180,870,180,870,180,240,780,240,6990;
20;37;Eurodomest;ID=0ec26f;SWITCH=00;CMD=OFF;
20;38;DEBUG;Pulses=52;Pulses(uSec)=30,150,360,660,360,660,330,690,960,90,360,660,390,660,960,90,960,90,960,90,960,90,330,720,930,90,930,120,300,720,330,690,930,120,300,720,330,720,300,720,300,720,930,120,930,120,930,120,270,750,300,6990;
20;39;DEBUG;Pulses=52;Pulses(uSec)=30,600,510,510,480,570,420,630,1020,30,390,630,420,630,1020,30,990,60,1020,30,990,60,360,660,960,90,960,90,300,720,330,690,960,90,330,690,330,690,330,690,330,690,930,90,930,120,930,120,300,720,300,6990;
20;3A;DEBUG;Pulses=50;Pulses(uSec)=330,750,270,750,270,750,900,150,270,750,270,750,900,150,900,150,900,150,900,150,270,750,870,150,870,150,240,780,270,780,870,180,240,780,240,780,240,780,270,780,870,180,870,180,870,180,240,780,240,6990;
20;3B;Eurodomest;ID=0ec26f;SWITCH=00;CMD=OFF;
20;3C;DEBUG;Pulses=36;Pulses(uSec)=1020,30,990,60,990,60,360,660,960,60,960,90,330,690,330,690,930,90,330,690,330,720,330,690,330,690,930,90,930,90,930,120,330,720,300,6990;
20;3D;DEBUG;Pulses=50;Pulses(uSec)=360,750,270,750,270,750,900,150,270,750,270,750,900,150,900,150,900,150,900,150,270,750,870,150,870,150,270,750,270,750,870,150,270,780,240,780,240,780,270,780,870,150,870,150,870,180,240,780,240,6990;
20;3E;Eurodomest;ID=0ec26f;SWITCH=00;CMD=OFF;
20;3F;DEBUG;Pulses=36;Pulses(uSec)=1020,30,960,60,960,60,360,660,990,60,960,90,330,690,360,660,930,90,330,690,330,720,300,720,330,690,930,90,930,90,930,90,330,720,300,6990;
20;40;DEBUG;Pulses=50;Pulses(uSec)=360,750,270,750,270,750,900,150,270,750,270,750,900,150,900,150,900,150,870,150,270,750,870,150,870,150,240,780,240,780,870,150,270,780,240,780,240,780,240,780,870,180,870,180,870,180,240,780,240,6990;
20;41;Eurodomest;ID=0ec26f;SWITCH=00;CMD=OFF;
Socket 1 On
Cheers
