I'm trying to control my ERA blinds (433MHz controlled) through RFLink and domoticz running on RPi.
I enabled debug mode and collected some logs (attached) for UP, STOP, DOWN button press on remote. The remote is able to control a group of blinds (2 in my case).
Can you confirm this device as unsupported? Is some kind of "known" protocol (ie somfy?)
Thanks,
C!
Support for ERA blinds
- tende.txt.zip
- (3.21 KiB) Downloaded 363 times
Re: Support for ERA blinds
Your system is using the Nice Era protocol.
This is a rolling code protocol which is currently not supported.
Thanks for your prompt reply!
Any chance to have it supported in the near future?
C!
C!
No, unless the Nice protocol gets hacked..
Correct me if I'm wrong: hacking the protocol is the standard way of inclusion for 433 devices.
If this is true, what is the procedure you normally follow for this "hacking" ? Is there any tool to use? Do you need a collection of remote key presses to understand and crack the rolling code?
Just curious but really interested in having my Nice ERA shutters controlled through Domoticz/RFLink.
Cheers,
C!
Cheers,
C!
