problem with mu esp12 Node MCU
Mihadongle
#1 Post by Mihadongle » 06 Sep 2016, 20:57
My esp12 reseted after i2c
INIT : Booting Build nr:120
IP   : Static IP :192.168.1.11
WIFI : Connecting... 1
WIFI : Disconnecting!
WIFI : Connecting... 2
WIFI : Connecting... 3
INIT : I2C
 ets Jan  8 2013,rst cause:4, boot mode:(3,6)
wdt reset
tail 8
chksum 0x2d
csum 0x2d
v09826c6d
~ld
ÿªU
WIFI : Connected!
INIT : I2C
wdt reset
tail 8
chksum 0x2d
csum 0x2d
v09826c6d
~ld
ÿªU
WIFI : Connected!
INIT : I2C
wdt reset
tail 8
chksum 0x2d
csum 0x2d
v09826c6d
~ld
ÿªU
I have Flash many versions but by all is the same!!
i have no idea, how could i reset the node complet? when i flash a version on it the setup (ip, all configs i make) are saved!! i think i have a problem with the setup but i couldn´t delet them!!!
please help
Mihadongle
Re: problem with mu esp12 Node MCU
#3 Post by Mihadongle » 08 Sep 2016, 10:40
thank you it works!!!!!!
