Hi there,
Where can I find the full documentation for the built-in commands aka tasknames like %ip%, %systime%, %uptime%, etc...
Thank you!
Built-in commands documentation (tasknames)?!
Re: Built-in commands documentation (tasknames)?!
Yes, I found that already, but I'm talking about LCD Display commands to show text messages from the system, like to display MAC address.
I don't know if there is a complete list. There are some on the wiki for the displays, and I think any task name from a plugin could be used.
Check the http://www.esp8266.nu/forum/viewtopic.php?f=6&t=55 thread, I am sure some will be there. I think that is a must read in any case.
If there is something you see in the interface you want to use, you can always check in the code to find the task name and give it a try. Sometimes looking at the code is very enlightening. I am not a programmer, but I find answers there faster than searching the forum some times.
Thanks! I found a few useful stuff!Drum wrote:I don't know if there is a complete list. There are some on the wiki for the displays, and I think any task name from a plugin could be used.
Can you please list it here?
