Is it posable to add the Bosch hood, type DID09T950 Bosch plafondunit
"+" button
20;78;DEBUG;Pulses=40;Pulses(uSec)=240,120,450,90,720,120,720,480,360,150,690,510,330,510,330,510,330,210,660,210,630,540,300,210,630,570,300,570,300,240,630,240,600,570,270,240,600,240,600,6990;
20;79;DEBUG;Pulses=38;Pulses(uSec)=420,180,660,180,660,540,330,210,630,540,300,540,300,540,300,210,630,240,630,570,300,240,630,570,300,570,300,240,600,240,600,570,270,240,600,240,600,6990;
20;7A;DEBUG;Pulses=38;Pulses(uSec)=420,180,660,210,630,540,300,210,630,540,300,540,300,540,300,240,630,240,600,570,270,240,600,600,270,600,270,270,570,270,570,630,240,300,570,300,540,6990;
20;7B;DEBUG;Pulses=38;Pulses(uSec)=420,210,660,210,630,570,300,240,630,570,300,570,300,570,270,240,600,240,600,570,270,240,600,600,270,600,270,240,600,240,600,600,270,270,600,270,600,6990;
20;7C;DEBUG;Pulses=38;Pulses(uSec)=420,180,660,210,630,540,300,210,630,540,300,570,300,570,300,240,630,240,600,570,270,240,600,570,270,570,270,240,600,240,600,570,270,240,600,240,600,6990;
"-" button
20;7D;DEBUG;Pulses=40;Pulses(uSec)=60,60,450,90,720,150,690,510,360,180,660,510,330,510,330,540,330,210,660,210,630,540,300,210,630,570,300,570,300,240,630,240,600,240,600,570,270,240,600,6990;
20;7E;DEBUG;Pulses=38;Pulses(uSec)=420,180,660,180,660,540,330,210,660,540,300,540,300,540,300,210,630,210,630,570,300,240,630,570,270,570,270,240,600,240,600,240,600,600,270,270,600,6990;
20;7F;DEBUG;Pulses=38;Pulses(uSec)=420,180,660,210,630,540,300,210,630,570,300,570,300,570,300,240,630,240,600,570,270,240,600,600,270,600,270,270,570,270,570,300,570,630,240,300,540,6990;
20;80;DEBUG;Pulses=38;Pulses(uSec)=420,210,660,210,630,540,300,210,630,570,300,570,300,570,300,240,630,240,600,570,270,240,600,570,270,570,270,240,600,240,600,270,600,600,270,270,600,6990;
20;81;DEBUG;Pulses=38;Pulses(uSec)=420,180,660,210,630,540,300,210,630,570,300,570,270,570,300,240,630,240,600,570,270,240,600,570,270,570,270,240,600,240,600,270,600,600,270,270,600,6990;
Light button
20;82;DEBUG;Pulses=38;Pulses(uSec)=420,90,720,150,690,480,360,180,660,510,330,510,330,540,330,210,630,210,630,540,300,210,630,570,300,570,300,240,630,240,600,570,300,570,300,240,600,6990;
20;83;DEBUG;Pulses=38;Pulses(uSec)=420,180,660,180,660,540,330,210,630,540,300,540,300,540,300,210,630,240,630,570,300,240,630,570,300,570,300,240,630,240,600,570,270,570,270,240,600,6990;
20;84;DEBUG;Pulses=38;Pulses(uSec)=420,180,660,180,660,540,300,210,630,570,300,570,300,570,300,240,630,240,600,570,270,240,600,600,270,600,270,240,600,270,570,600,240,630,240,300,570,6990;
20;85;DEBUG;Pulses=38;Pulses(uSec)=420,210,660,210,630,570,300,240,600,570,300,570,300,570,270,240,600,240,600,570,270,240,600,570,270,570,270,240,600,240,600,600,270,600,270,240,600,6990;
20;86;DEBUG;Pulses=38;Pulses(uSec)=420,180,660,180,660,540,330,210,630,540,300,570,300,570,300,240,630,240,600,570,270,240,600,600,270,570,270,240,600,270,600,600,270,600,270,240,600,6990;
Intensive
20;8C;DEBUG;Pulses=38;Pulses(uSec)=660,90,750,120,690,510,360,150,660,510,330,510,330,540,330,210,660,210,630,540,300,210,630,540,300,570,300,240,630,240,600,570,300,240,600,570,270,6990;
20;8D;DEBUG;Pulses=38;Pulses(uSec)=420,180,660,180,660,510,330,210,660,540,300,540,300,540,300,210,630,240,630,570,300,240,630,570,270,570,270,240,600,240,600,570,270,240,600,600,270,6990;
20;8E;DEBUG;Pulses=38;Pulses(uSec)=420,180,660,180,660,540,300,210,630,540,300,570,300,570,300,240,600,240,600,570,270,240,600,570,270,570,270,270,600,270,570,600,240,300,570,630,240,6990;
20;8F;DEBUG;Pulses=38;Pulses(uSec)=420,210,660,210,630,540,300,240,600,570,300,570,300,570,300,240,630,240,600,570,270,240,600,570,270,570,270,240,600,240,600,600,270,270,600,600,270,6990;
20;90;DEBUG;Pulses=38;Pulses(uSec)=420,180,660,180,630,540,300,210,630,570,300,570,300,570,300,240,600,240,600,570,270,240,600,600,270,570,270,240,600,240,600,600,270,240,600,600,270,6990;
Timer
20;91;DEBUG;Pulses=36;Pulses(uSec)=750,120,690,510,360,180,660,510,330,510,330,510,330,180,630,210,630,540,300,210,630,570,300,570,300,240,630,240,630,240,600,240,600,570,270,6990;
20;92;DEBUG;Pulses=38;Pulses(uSec)=420,180,660,180,660,540,330,210,660,540,300,540,300,540,300,210,630,240,630,570,300,240,600,570,270,570,270,240,600,240,600,240,600,270,600,600,270,6990;
20;93;DEBUG;Pulses=38;Pulses(uSec)=420,180,660,210,660,540,300,210,630,570,300,570,300,570,300,240,600,240,600,570,270,240,600,600,270,600,270,270,570,270,570,300,540,300,540,630,210,6990;
20;94;DEBUG;Pulses=38;Pulses(uSec)=420,210,660,210,630,540,300,210,630,570,300,570,300,570,300,240,630,240,600,570,270,240,600,570,270,570,270,240,600,240,600,270,600,270,600,600,270,6990;
20;95;DEBUG;Pulses=38;Pulses(uSec)=420,180,660,210,630,540,300,210,630,570,300,570,300,570,300,240,600,240,600,570,270,240,600,570,270,570,270,240,600,240,600,270,600,270,600,600,270,6990;
Thanks, Mulder
Support for Bosch hood
- Bosch_hood_remote_control_2.jpg (204.61 KiB) Viewed 6398 times
- Bosch_hood_remote_control_1.jpg (223.76 KiB) Viewed 6398 times
Re: Support for Bosch hood
Should be possible.. We will make a test version and contact you.
Hi all,
a follow up on quite an old topic.
I've got the same remote control (SF-01) and the RF433 codes are received by RFLink (20;58;Bosch;ID=6e43;SWITCH=2;CMD=ON;).
However, if I send the same code it doesn't do anything (10;Bosch;6e43;2;ON;). Why could that happen? Is here a solution for this?
Thanks in advance,
Kees
Thanks in advance,
Kees
Is there anybody who managed to get this ventilation hood running with RFLink?
Love to get in touch!
/Kees
/Kees
