Use multiple ESP with different sensors, GREAT work for this cheap board!!
I use the espeasy icw Domoticz [ always the last beta ]
1 problem.
I use 1 esp nodemuc for the control of my pellet stove.
Almost perfect.
1 problem, the relais i give the Http command like in the wiki.
http://<ESP IP address>/control?cmd=GPIO,<pin>,0
http://<ESP IP address>/control?cmd=GPIO,<pin>,1
And the esp is switching in Domoticz 1 second. [ Only this second is to long.
Is there perhaps a option to switch the Http command with milliseconds?
Like:
Short pulses
To send a pulse to a certain pin:
http://<ESP IP address>/control?cmd=Pulse,<pin>,<state>,<duration>
Example to send an active high pulse on GPIO 2 for 500 mSeconds:
http://<ESP IP address>/control?cmd=Pulse,2,1,500
Or are there better options?
