generic HTTP Request: length and variables of template?
groovy
#1 Post by groovy » 14 Oct 2016, 13:00
Hi from Germany,
I just discovered this project and I like it.
I set up my first ESP some hours ago and configured almost everything without a hassle.
When it comes to sending the data, I want to use "Generic HTTP" as I have a server running, which receives a request (currently nodeMCU, but want to switch to ESPEasy) in the form:
index.php?app=shc&a&ajax=pushsensorvalues&spid=3&sid=30&type=2&v1=22.4&v2=43.2
where "spid" is actually the "sensorpoint-ID", "sid" is the sensor-ID, "type" is the type of sensor (and 2 is for DHT) and "v1" and "v2" are the actual values for temperature and humidity.
For a DS18b20, there will be only "v1", for a BME280 there would be "v1", "v2" and "v3".
Given the above example, I:
- named the device "3", being the sensorpoint-ID with the variable %sysname%
- named the task for the DHT "30", being the sensor-ID with the variable %tskname%
- gave the IDX the number "2", being the sensortype with the variable %IDX% (which doesn't work)
- named the value 1 "v1", with the variable %valname%
- named the value 2 "v2", with the variable %valname% (?)
So I assembled the following template-string:
index.php?app=shc&a&ajax=pushsensorvalues&spid=%sysname%&type=%IDX%&sid=%tskname%&%valname%=%value%
This doesn't work.
The first problem is the length. The resulting request is cut right after %tskname, so the allowed length seems to be 80 chars only. I can enter the whole string, but by submitting it, it gets cut.
Second problem so far, the %IDX% is not getting "translated" into the value. I did not found a documentation where all possible variables are listed, only for the system-variables.
There's only an example string with some possible variables before one replaces this with his own template.
So I have 3 questions:
1. Is there any documentation with possible variables for putting together the template?
2. How is the varying number of possible %valname%=%value%-pairs, depending on the sensortype, handled? When I put that in my template only once (as above), will the other 1 or 2 be appended? Or will they be discarded? What's the "best practice" for this?
3. Is it possible to expand the length of the template when I build the firmware on my own? Will do this anyway, as I want to read VCC.
Thanks in advance
groovy
Re: generic HTTP Request: length and variables of template?
#2 Post by groovy » 15 Oct 2016, 13:00
Just took a look at the code.
For my third question I think I found the corresponding line in _C008.ino:
url.toCharArray(log, 80);
Am I right with my assumption? Can I simply rise that value?
For the not-working %IDX% variable I found the line:
url.replace("%id%", String(event->idx));
So that is solved too, I think.
What I didn't found until now is: How can I form the template to send more than one %valname%=%value%-pairs. Can anyone help me on this?
groovy
#3 Post by groovy » 16 Oct 2016, 14:47
Giving myself an answer again :)
In addition to my found
in _C008.ino changing to 120, I changed the following:
in Webserver.ino, line 1767:
mqttpublish.toCharArray(tmpString, 121);
(was 81) and in line 1812:
reply += F("'><TR><TD>Publish Template:<TD><input type='text' name='mqttpublish' size=120 value='");
(was 80). And in ESPEasy.ino, line 315:
char          MQTTpublish[121];
(was 81).
This gave me the complete string for my template and actually works for a DHT22 and VCC.
For a DS18b20, also connected, the ESP crashes/reboots after a successful read. Have to investigate more on this. The log shows:
WD : Uptime 0 ConnectFailures 0 FreeMem 28392
34996 : SYS : 3.24
34997 : EVENT: 99#v1=3.24
36020 : DHT : Temperature: 27.30
36020 : DHT : Humidity: 32.60
36020 : EVENT: 30#v1=27.30
36020 : EVENT: 30#v2=32.60
41631 : DS : Temperature: 26.44 (28-ff-bc-77-3b-4-0-2c)
41631 : EVENT: 28-abcdef0003#v1=26.44
and then the ESP reboots.
For this:
I found, that ESPEasy just sends a separate HTTP-request for every %valname%=%value%-pair. Will have a look, how to manage this behaviour.
sibianul
#4 Post by sibianul » 28 Jun 2017, 12:38
I just found out this awesome project yesterday, today I got a spare D1 mini and flashed the firmware to it .. Awesome guys! Well done, you made everything so simple :)
Now, my problem is related to pushing the data to my BananaPi server, I also use Generic HTTP protocol but if I check the apache access.log on the BananaPi i get the exact same text I saved in the Publish template, not the actual values.
Anyone around to give me some instructions ?
Apache log
192.168.1.103 - - [28/Jun/2017:12:55:15 +0300] "GET /push.php?name=%esp_sys_info%&id=%41%&value=%esp_sys_info% HTTP/1.1" 200 166 "-" "-"
192.168.1.103 - - [28/Jun/2017:12:56:12 +0300] "GET /push.php?name=%esp_sys_info%&id=%41%&value=%esp_sys_info% HTTP/1.1" 200 166 "-" "-"
192.168.1.103 - - [28/Jun/2017:12:56:15 +0300] "GET /push.php?name=%esp_sys_info%&id=%41%&value=%esp_sys_info% HTTP/1.1" 200 166 "-" "-"
esp easy advanced.png (32.21 KiB) Viewed 9821 times
Any help is appreciated!
krikk
#5 Post by krikk » 28 Jun 2017, 13:33
give the Generic HTTP Advanced Protocol a try, you have to use a -dev or -testing build of th 2.x firmware... could probably solve your issues?
sibianul
#6 Post by sibianul » 28 Jun 2017, 15:45
I flashed the v2.0.0 dev10 firmware, but I still need some help understanding the URL structure.
I seen it's a big difference from the latest stable Ihad before to this dev firmware, alot more sensors, the controller and notification tab .. but I still don;t know how to setup the controller to send the data from all the devices I have setup. So far as I didn't connected any sensor to the ESP I want just to send the sys information like load ..uptime, if I will make this work I will be able to setup other sensors also :)
The ESP was pushing the URL to my BananaPi but for sure it was me that made a mistake, as even now with the dev firmware it still push the text I wrote ion the URL instead of the value, can you guys tell me what I should write in the controller page , is there any documentation regarding General HTTP?
PS. I noticed the ping response is also faster, can you guys tell me if the stable firmware version should be the same as this, because I noticed multiple times the stable firmware not responding to my browser request, also ping response was even 300ms, now I have it constant at 1ms (sometimes 2ms .. but rarely) but so far the uptime is just a few minutes.
Thank you
krikk
#7 Post by krikk » 28 Jun 2017, 21:03
please read the info on the wiki i linked in my post!
push.php?sensor_name=%vname1%&value=%val1%
this should work for every sensor which only publishes one value like the sysinfo
sibianul
#8 Post by sibianul » 28 Jun 2017, 21:16
Thanks krikk, I just figured out minutes ago that I have to use exactly the variable %vname1% and %val1% for the first sensor, instead the name of the sensor , that I used in my test :)
I checked apache log and found exactly what I wanted :)
192.168.1.41 - - [28/Jun/2017:22:03:50 +0300] "GET /push.php?esp%5fsys%5finfo%5fvalue=23.00&=0.00 HTTP/1.1" 200 166 "-" "-"
192.168.1.41 - - [28/Jun/2017:22:03:51 +0300] "GET /push.php?load%5fvalue=7.00&=0.00 HTTP/1.1" 200 166 "-" "-"
Now I will start mounting the relay and temperature/humidity sensor, the relay is for my office led lights, now a few months ago I made all the HTML code on the ESP to look as nice as I could, but I don't know what I messed up and it didn't work anymore, but now I will use the BananaPi to store all the values and to have the dashboard of all my sensors.
But as now I have so little time to play with those thinkgs, I really appreciate your firmware, as this will help me acomplish my goal faster, with spending fewer time on codding all the sensors reading and activation. .. this is how it look in the past, with all the code loaded from ESP .. the graph ware looking great, led light was working ... but that was it, now the Dashboard I work on will contain much more informations
Users browsing this forum: No registered users and 44 guests
