Support Request for SilverCrest 3711A / 113854 power switch
Post here about devices that are not yet or not fully supported
RabbitAtNet
#1 Post by RabbitAtNet » 31 Oct 2016, 00:20
Hi RFLink-Team,
I got myself some cheap remote controlled power switches from LIDL, marketed as SilverCrest 113854 (RCR DS1 3711-A). Unfortunately, they are not yet supported by RFLink - an amazing piece of hard- and software by the way.
They come with a declaration of conformity by the German company Brennenstuhl (http://www.brennenstuhl.de/), which leads me to believe they are the original manufacturer.
There is also a compatible set of power switch out there, which was sold by Aldi as Quigg GT9000.
SilverCrest 113854 user manual:
http://www.dvw-service.com/index.php?mo ... 621_ba.pdf
The power switch has to be paired with the remote control. For that, you plug the power switch into a wall socket and within 30 seconds press the desired channel on the remote control.
The protocol seems to be quite complicated. I found these two online discussions, which I guess relate to my power switch set:
[*]https://github.com/sui77/rc-switch/pull/11
[*]https://forum.pilight.org/Thread-QUIGG- ... LDI?page=8
Here are the signals the RFLink intercepted in debug mode:
Channel A / ON
First Try
20;2C;DEBUG;Pulses=200;Pulses
(uSec)=270,1140,180,1110,960,360,210,1110,210,1110,960,360,210,1110,210,1110,960,360,210,1110,210,1110,210,1110,960,360,960,390,960,360,210,1110,210,1110,960,360,960,360,210,1110,960,360,960,360,210,1110,210,1110,210,2250,210,1110,210,1110,960,360,210,1110,210,1110,960,360,210,1140,180,1110,960,360,210,1110,210,1110,210,1110,960,360,960,360,960,360,210,1110,180,1110,960,360,960,360,180,1110,960,360,960,360,180,1110,210,1110,210,2250,210,1110,210,1110,960,360,210,1110,210,1110,960,360,210,1110,210,1110,960,360,210,1110,210,1110,210,1110,960,360,960,360,960,360,210,1110,210,1110,960,360,960,360,210,1110,960,360,960,360,210,1110,210,1110,210,2250,210,1110,210,1110,960,360,180,1110,210,1110,960,360,210,1110,210,1110,960,360,210,1110,210,1140,180,1110,960,360,960,360,960,360,210,1110,210,1110,960,360,960,360,210,1110,960,360,960,360,210,1110,210,1140,2850,6990;
20;2D;DEBUG;Pulses=38;Pulses
(uSec)=870,450,330,930,300,930,810,480,330,990,330,990,330,990,840,480,840,480,840,480,330,990,330,990,840,480,840,480,330,990,840,480,840,480,330,990,330,6990;
Second Try
20;2E;DEBUG;Pulses=200;Pulses
(uSec)=270,1110,210,1110,960,360,210,1110,960,360,960,360,180,1110,960,390,180,1110,960,360,210,1110,210,1110,180,1110,960,360,960,360,960,360,180,1110,210,1110,210,1110,960,360,960,360,960,360,210,1110,210,1110,210,2250,180,1110,210,1110,960,360,210,1110,960,360,960,360,210,1110,960,360,210,1140,960,360,180,1110,210,1110,210,1110,960,360,960,360,960,360,210,1110,210,1140,180,1110,960,360,960,360,960,360,210,1110,210,1110,210,2250,180,1110,210,1110,960,360,210,1110,960,360,960,360,210,1110,960,360,210,1110,960,390,180,1110,210,1140,180,1110,960,360,960,360,960,360,210,1110,210,1110,210,1110,960,360,960,360,960,360,210,1110,210,1140,210,2220,210,1110,180,1110,960,360,210,1110,960,360,960,360,210,1110,960,360,210,1140,960,360,210,1110,210,1110,180,1110,960,360,960,360,960,360,210,1110,210,1110,210,1140,960,360,960,360,960,360,210,1110,210,1140,2850,6990;
20;2F;DEBUG;Pulses=40;Pulses
(uSec)=30,450,780,480,300,960,780,480,330,990,840,480,330,990,330,990,330,990,840,510,840,480,840,510,330,990,330,990,330,990,840,510,840,480,840,480,330,990,330,6990;
Channel A / Off
Frist Try
20;3A;DEBUG;Pulses=202;Pulses
(uSec)=0,2550,180,1110,210,1110,960,360,210,1110,210,1110,960,360,960,360,960,360,960,360,210,1110,210,1110,960,360,960,360,960,360,960,360,960,360,210,1110,210,1110,960,360,210,1110,960,360,960,360,210,1110,210,1110,210,2250,210,1110,210,1110,960,360,210,1110,180,1110,960,360,960,360,960,390,930,360,210,1110,210,1140,960,360,960,360,960,360,960,360,960,360,210,1110,210,1110,960,360,210,1110,960,360,960,360,210,1110,210,1110,210,2220,210,1110,210,1110,960,360,210,1110,180,1110,960,360,960,360,960,360,960,360,210,1110,180,1110,960,360,960,360,960,360,960,360,960,360,210,1110,210,1110,960,360,180,1110,960,360,960,360,210,1110,210,1110,210,2250,210,1110,210,1110,960,360,210,1110,210,1110,960,360,960,360,960,360,960,360,210,1110,210,1110,960,360,960,360,960,360,960,360,960,360,210,1140,180,1110,960,360,210,1110,960,360,960,360,210,1110,210,1140,2850,6990;
20;3B;DEBUG;Pulses=44;Pulses
(uSec)=360,450,330,930,300,930,780,450,780,450,780,480,840,480,330,990,330,990,840,510,840,480,840,480,840,480,840,480,330,990,330,1020,810,480,330,990,840,480,840,480,330,990,330,6990;
Second Try
20;3E;DEBUG;Pulses=200;Pulses
(uSec)=270,1140,180,1110,960,360,210,1110,960,360,210,1110,960,360,210,1110,210,1110,210,1140,960,360,960,360,960,360,210,1110,210,1110,960,360,960,360,210,1110,210,1110,210,1110,960,360,960,360,210,1110,180,1140,210,2250,210,1140,180,1140,960,360,210,1110,960,360,210,1110,960,360,210,1110,210,1110,210,1110,960,360,960,360,960,360,180,1110,210,1110,960,360,960,360,210,1110,210,1110,210,1110,960,360,960,360,210,1110,210,1140,210,2250,210,1110,210,1110,960,360,180,1140,960,360,210,1110,960,360,210,1110,210,1110,210,1110,960,360,960,360,960,360,210,1110,210,1110,960,360,960,360,210,1110,210,1110,210,1110,960,360,960,360,210,1110,210,1110,210,2250,180,1110,210,1110,960,360,210,1110,960,360,210,1110,960,360,210,1110,210,1110,210,1110,960,360,960,360,960,360,210,1110,210,1110,960,360,960,360,210,1110,210,1110,210,1110,960,360,960,360,210,1110,210,1140,2850,6990;
20;3F;DEBUG;Pulses=38;Pulses
(uSec)=360,930,810,450,330,930,300,990,330,990,840,480,840,480,840,480,330,990,330,990,840,480,840,480,330,990,330,990,330,990,840,510,840,480,330,990,330,6990;
Channel B / On
Frist Try
20;43;DEBUG;Pulses=200;Pulses
(uSec)=270,1110,210,1110,960,360,210,1110,960,360,210,1140,180,1110,210,1110,210,1110,210,1140,180,1110,960,360,210,1110,960,360,180,1110,210,1110,210,1110,210,1110,210,1110,210,1110,210,1110,960,360,210,1110,930,360,210,2220,210,1110,210,1110,960,360,210,1110,960,360,210,1110,210,1110,210,1110,210,1110,210,1110,210,1110,960,360,210,1110,960,360,180,1140,210,1110,210,1110,210,1110,210,1110,210,1110,210,1110,960,360,210,1110,960,360,210,2250,210,1110,210,1110,960,360,210,1110,960,360,210,1110,210,1110,210,1110,210,1110,210,1110,210,1110,960,360,210,1110,960,360,180,1110,210,1110,210,1110,210,1110,210,1110,210,1110,210,1110,960,360,210,1110,960,360,210,2250,210,1110,210,1110,960,390,180,1110,960,360,210,1110,210,1110,210,1110,210,1110,210,1110,210,1110,960,360,210,1110,960,360,210,1110,210,1110,210,1110,210,1110,210,1110,210,1110,180,1110,960,360,210,1110,960,390,2850,6990;
20;44;DEBUG;Pulses=34;Pulses
(uSec)=390,930,300,930,300,960,300,990,840,480,330,990,840,510,330,990,330,990,330,990,330,990,330,990,330,990,330,990,840,480,330,990,840,6990;
Second Try
20;49;DEBUG;Pulses=200;Pulses
(uSec)=270,1110,210,1140,960,360,210,1110,960,360,960,360,210,1110,210,1110,960,360,960,360,210,1110,210,1110,210,1110,210,1110,960,360,960,360,960,360,960,360,960,360,210,1110,210,1110,960,360,210,1110,960,360,210,2250,210,1110,180,1110,960,360,180,1110,960,360,960,360,210,1110,210,1110,960,360,960,360,210,1110,210,1110,210,1110,210,1110,960,360,960,360,960,360,960,360,960,360,210,1110,210,1110,960,360,180,1110,960,360,210,2250,210,1110,210,1110,960,390,180,1110,960,360,960,360,210,1110,210,1110,960,360,960,360,210,1110,210,1110,210,1110,210,1110,960,360,960,360,960,360,960,360,960,360,210,1110,210,1110,960,360,210,1110,960,360,210,2250,210,1110,210,1110,960,360,210,1110,960,360,960,360,210,1140,180,1110,960,360,960,360,210,1110,210,1110,210,1110,210,1110,960,360,960,360,960,360,960,360,960,360,210,1110,210,1110,960,360,210,1110,960,360,2880,6990;
20;4A;DEBUG;Pulses=40;Pulses
(uSec)=720,450,810,450,300,960,300,960,840,510,840,480,330,1020,330,990,330,990,330,990,840,480,840,480,840,480,840,480,840,480,330,990,330,990,840,480,330,990,840,6990;
Channel B / Off
Frist Try
20;4F;DEBUG;Pulses=202;Pulses(uSec)=30,2520,210,1110,210,1110,960,360,210,1110,210,1110,210,1110,960,360,960,360,210,1110,960,360,960,360,210,1110,960,360,210,1110,180,1110,210,1110,960,360,210,1140,180,1110,960,360,180,1140,960,360,210,1110,960,360,210,2250,210,1110,210,1110,960,360,210,1110,210,1110,210,1110,960,360,960,360,210,1110,960,360,960,360,210,1110,960,360,210,1110,210,1110,210,1110,960,360,180,1110,210,1140,960,360,210,1110,960,360,210,1110,960,360,210,2250,210,1110,210,1110,960,360,210,1110,210,1110,210,1110,960,360,960,360,210,1110,960,360,960,360,210,1110,960,360,210,1110,210,1110,210,1110,960,360,210,1110,180,1110,960,360,210,1110,960,360,210,1110,960,360,210,2250,210,1140,180,1110,960,360,210,1110,210,1140,180,1110,960,360,960,360,210,1110,960,360,960,360,210,1110,960,360,210,1110,210,1110,210,1110,960,360,210,1110,210,1140,960,360,180,1110,960,360,180,1110,960,390,2820,6990;
20;50;DEBUG;Pulses=40;Pulses(uSec)=390,930,300,930,780,450,780,450,300,930,810,480,840,480,330,990,840,480,330,990,330,990,330,1020,810,480,330,990,330,990,840,480,330,990,840,480,330,1020,840,6990;
Second Try
20;55;DEBUG;Pulses=202;Pulses(uSec)=30,2520,210,1110,180,1110,960,360,180,1110,960,360,210,1110,210,1110,960,360,210,1110,210,1110,210,1110,210,1110,960,360,960,360,210,1110,960,360,960,390,930,360,210,1110,210,1110,210,1110,960,360,210,1110,960,360,210,2250,210,1110,210,1110,960,360,210,1110,960,360,210,1110,210,1110,960,360,210,1110,210,1110,210,1110,210,1110,960,360,960,360,210,1110,960,360,960,360,960,360,210,1110,210,1110,210,1110,960,360,210,1110,960,360,180,2250,210,1110,210,1110,960,390,180,1110,960,360,210,1110,210,1110,960,360,180,1110,210,1110,210,1110,210,1110,960,360,960,360,210,1110,960,360,960,360,960,360,210,1110,210,1110,210,1110,960,360,210,1110,960,360,210,2250,210,1110,210,1110,960,360,210,1110,960,360,210,1110,210,1110,960,360,210,1110,210,1110,210,1110,210,1110,960,360,960,360,210,1110,960,360,960,360,960,360,210,1110,210,1110,210,1110,960,360,210,1110,960,360,2850,6990;
20;56;DEBUG;Pulses=40;Pulses(uSec)=870,450,300,930,300,930,780,450,330,930,300,990,330,990,330,990,840,510,840,480,330,990,840,480,840,480,840,480,330,990,330,990,330,990,840,510,330,990,840,6990;
Channel C / On
Frist Try
20;5B;DEBUG;Pulses=200;Pulses(uSec)=270,1110,210,1140,960,360,210,1110,960,360,210,1110,960,360,180,1110,210,1110,210,1110,960,360,960,360,960,360,210,1110,210,1110,960,360,960,360,210,1110,180,1110,210,1110,960,360,960,360,960,360,210,1110,210,2250,210,1110,180,1110,960,360,210,1110,960,360,210,1110,960,360,210,1110,210,1110,210,1110,960,360,960,360,960,360,210,1110,210,1110,960,360,960,360,210,1110,210,1110,210,1110,960,360,960,360,960,360,210,1110,210,2250,180,1110,210,1110,960,360,210,1110,960,360,210,1110,960,360,210,1110,210,1110,210,1110,960,360,960,360,960,360,210,1140,180,1140,960,360,960,360,210,1110,210,1110,210,1110,960,360,960,360,960,360,210,1110,210,2250,210,1110,210,1110,960,360,210,1110,960,360,180,1110,960,360,210,1110,210,1110,210,1110,960,360,960,360,960,360,210,1110,210,1110,960,360,960,360,210,1110,210,1140,180,1110,960,360,960,360,960,390,180,1110,2850,6990;
20;5C;DEBUG;Pulses=40;Pulses(uSec)=60,480,300,930,810,450,300,930,330,990,330,990,840,480,840,480,840,480,330,990,330,990,840,480,840,510,330,990,330,990,330,990,840,480,840,480,840,480,330,6990;
Second Try
20;63;DEBUG;Pulses=200;Pulses(uSec)=270,1110,210,1110,960,360,210,1140,930,360,210,1110,960,360,210,1110,210,1110,210,1110,960,360,960,360,960,360,210,1140,180,1110,960,360,960,360,210,1110,210,1140,180,1110,960,390,930,360,960,360,210,1140,180,2250,210,1110,210,1110,960,360,210,1110,960,360,210,1110,960,360,210,1110,210,1110,210,1110,960,360,960,360,960,360,180,1110,210,1110,960,360,960,360,210,1110,210,1110,210,1110,960,360,960,360,960,360,180,1110,210,2250,210,1110,210,1140,960,360,210,1110,960,360,210,1110,960,360,210,1110,210,1110,210,1110,960,360,960,360,960,360,210,1110,210,1110,960,360,960,360,210,1110,210,1110,210,1110,960,360,960,360,960,360,210,1110,210,2250,210,1110,210,1110,960,360,210,1110,960,360,210,1110,960,360,210,1110,210,1110,210,1110,960,360,960,360,960,360,210,1140,210,1110,960,360,960,360,210,1110,210,1110,210,1110,960,360,960,360,960,360,210,1110,2850,6990;
20;64;DEBUG;Pulses=40;Pulses(uSec)=90,450,330,930,780,450,300,930,330,990,330,990,840,480,840,480,840,480,330,990,330,990,840,480,840,510,330,990,330,990,330,990,840,480,840,480,840,480,330,6990;
Channel C / Off
First Try
20;67;DEBUG;Pulses=200;Pulses(uSec)=270,1110,210,1110,960,360,210,1110,210,1110,960,360,210,1110,210,1140,960,360,210,1110,210,1110,180,1110,960,360,960,360,960,360,210,1110,210,1110,960,360,960,360,210,1110,960,360,960,360,960,360,210,1110,210,2250,180,1110,210,1110,960,360,210,1110,210,1110,960,360,210,1110,210,1110,960,360,210,1110,210,1110,210,1110,960,360,960,360,960,360,210,1110,210,1110,960,360,960,360,210,1110,960,360,960,360,960,360,210,1110,210,2250,210,1110,210,1110,960,360,210,1140,180,1110,930,360,210,1110,210,1110,960,360,210,1110,210,1110,210,1110,960,360,960,360,960,360,210,1110,210,1110,960,360,960,390,180,1110,960,360,960,360,960,360,210,1110,210,2250,210,1110,210,1110,960,360,210,1110,210,1110,960,360,210,1110,180,1110,960,360,210,1110,210,1110,210,1110,960,360,960,360,960,360,180,1110,210,1110,960,360,960,360,210,1110,960,360,960,360,960,360,210,1140,2850,6990;
20;68;DEBUG;Pulses=38;Pulses(uSec)=870,450,330,930,300,930,810,510,330,990,330,990,330,990,840,480,840,480,840,480,330,990,330,990,840,480,840,480,330,990,840,480,840,480,840,480,330,6990;
Second Try
20;6B;DEBUG;Pulses=200;Pulses(uSec)=270,1110,210,1140,960,360,210,1110,210,1110,180,1110,210,1110,210,1110,210,1110,210,1110,960,360,210,1140,210,1140,180,1110,960,360,210,1110,210,1110,960,360,210,1110,960,360,960,360,960,360,960,360,210,1110,210,2250,210,1110,210,1110,960,360,210,1140,180,1110,210,1110,210,1110,210,1110,210,1110,180,1110,960,360,210,1110,210,1110,210,1110,960,360,210,1110,210,1110,960,360,210,1110,960,360,960,360,960,360,960,360,210,1140,180,2250,210,1110,210,1110,960,360,180,1110,210,1110,210,1110,210,1110,210,1110,210,1110,210,1110,960,360,180,1110,210,1110,210,1140,930,360,210,1110,210,1140,960,360,210,1110,960,360,960,360,960,360,960,360,210,1110,210,2250,210,1110,210,1110,960,360,210,1110,210,1110,210,1110,210,1110,180,1110,210,1110,210,1110,960,360,210,1140,180,1110,210,1140,960,360,210,1140,180,1110,960,360,210,1110,960,360,960,360,960,360,960,390,180,1140,2850,6990;
20;6C;DEBUG;Pulses=36;Pulses(uSec)=390,930,300,930,300,930,300,990,840,510,330,990,330,990,330,990,840,480,330,990,330,990,840,510,330,990,840,480,840,480,840,480,840,480,330,6990;
Channel D / On
Frist Try
20;6D;DEBUG;Pulses=200;Pulses(uSec)=270,1110,210,1110,960,360,210,1140,960,360,960,360,960,360,960,360,960,360,210,1110,960,360,210,1110,960,360,960,360,210,1110,210,1110,210,1110,960,390,180,1110,210,1110,210,1110,960,360,960,360,960,360,210,2250,210,1110,210,1110,960,360,210,1110,960,360,960,360,960,360,960,360,960,360,180,1110,960,360,210,1110,960,360,960,360,180,1110,210,1110,210,1110,960,360,210,1110,210,1110,210,1110,960,360,960,360,960,360,210,2250,210,1110,210,1110,960,360,210,1110,960,360,960,360,960,360,960,360,960,360,210,1110,960,360,180,1110,960,360,960,360,210,1110,210,1110,210,1110,960,360,210,1110,180,1110,210,1110,960,360,960,360,960,360,210,2250,210,1110,210,1110,960,360,210,1110,960,360,960,360,960,360,960,360,960,360,210,1110,960,360,210,1110,960,360,960,360,210,1110,210,1110,210,1110,960,360,210,1110,210,1110,210,1110,960,360,960,360,960,360,2850,6990;
20;6E;DEBUG;Pulses=40;Pulses(uSec)=870,450,780,450,780,450,810,480,840,510,330,990,840,510,330,990,840,480,840,480,330,990,330,990,330,990,840,480,330,990,330,990,330,990,840,480,840,480,840,6990;
Second Try
20;6F;DEBUG;Pulses=202;Pulses(uSec)=60,2550,180,1110,210,1110,960,330,210,1110,990,360,210,1110,210,1110,990,360,210,1110,210,1110,210,1110,210,1110,960,330,990,360,210,1110,960,360,960,330,990,330,210,1110,210,1110,210,1110,990,360,960,360,990,330,210,2250,210,1140,180,1140,960,360,210,1110,960,360,210,1140,180,1110,960,360,180,1110,210,1110,210,1110,210,1110,960,360,960,360,210,1110,960,360,960,360,960,360,210,1110,210,1110,210,1110,960,360,960,360,960,360,210,2250,210,1110,210,1110,960,360,210,1110,960,360,210,1110,210,1110,960,360,210,1110,210,1110,210,1110,210,1110,990,330,990,360,210,1110,960,330,990,330,990,360,210,1110,210,1110,210,1110,990,360,960,360,960,330,210,2250,210,1110,210,1110,960,360,210,1110,990,360,210,1110,210,1110,960,360,210,1110,210,1110,210,1110,240,1110,990,330,990,330,210,1080,990,390,930,330,990,360,210,1080,210,1110,210,1110,960,360,960,330,990,360,2850,6990;
20;70;DEBUG;Pulses=42;Pulses(uSec)=60,930,810,450,330,930,330,960,780,450,300,930,330,960,360,990,330,960,840,480,840,480,330,1020,810,480,840,510,840,480,330,990,330,990,330,990,840,480,840,510,840,6990;
Channel D / Off
First Try
20;71;DEBUG;Pulses=200;Pulses(uSec)=270,1110,210,1110,960,360,210,1110,960,360,210,1110,210,1110,210,1110,210,1110,210,1110,210,1110,960,360,210,1110,960,360,210,1110,210,1110,210,1110,210,1110,210,1110,210,1110,210,1110,960,360,960,390,930,360,210,2250,210,1110,210,1110,960,360,210,1110,960,360,210,1110,210,1110,210,1110,210,1140,180,1110,210,1140,960,360,180,1110,960,360,180,1110,210,1110,210,1110,210,1110,210,1110,210,1110,210,1110,960,360,960,360,960,360,210,2250,210,1110,210,1110,960,360,210,1110,960,360,210,1110,210,1110,210,1110,210,1110,210,1110,210,1110,960,360,180,1110,960,360,210,1110,210,1110,210,1110,210,1110,210,1110,210,1110,210,1110,960,360,960,360,960,360,210,2250,210,1110,210,1110,960,360,210,1110,960,360,210,1110,210,1110,210,1110,210,1110,210,1110,210,1110,960,360,210,1110,960,360,210,1110,210,1110,180,1110,210,1110,210,1110,210,1110,210,1110,960,360,960,360,960,360,2850,6990;
20;72;DEBUG;Pulses=34;Pulses(uSec)=390,930,300,930,300,960,330,990,840,510,330,990,840,510,330,990,330,990,330,990,330,990,330,990,330,990,330,990,840,480,840,480,840,6990;
Second Try
20;73;DEBUG;Pulses=200;Pulses(uSec)=270,1110,210,1140,960,360,210,1140,960,360,960,360,960,360,210,1140,930,360,960,360,960,360,180,1110,210,1110,210,1110,210,1110,960,360,210,1110,210,1110,960,360,960,360,210,1110,960,360,960,360,960,360,210,2250,210,1110,210,1140,930,360,210,1140,930,360,960,360,960,360,210,1110,960,360,960,360,960,360,210,1110,210,1110,210,1110,210,1110,960,360,210,1110,180,1110,960,360,960,360,210,1110,960,360,960,360,960,360,210,2250,180,1110,210,1110,960,360,210,1110,960,360,960,360,960,360,210,1110,960,360,960,360,960,360,210,1110,210,1110,210,1110,210,1110,960,360,210,1110,210,1110,960,360,960,360,210,1110,960,360,960,360,960,360,210,2250,210,1110,210,1110,960,360,210,1110,960,360,960,360,960,360,210,1140,930,360,960,360,960,360,210,1110,210,1110,210,1110,210,1110,960,360,210,1110,210,1110,960,360,960,360,210,1110,960,360,960,360,960,360,2850,6990;
20;74;DEBUG;Pulses=40;Pulses(uSec)=870,450,780,450,780,450,330,990,840,480,840,480,840,510,330,990,330,990,330,990,330,990,840,480,330,1020,300,990,840,510,840,480,330,990,840,480,840,480,840,6990;
Master On - power up all switches
First Try
20;75;DEBUG;Pulses=200;Pulses(uSec)=270,1110,210,1110,960,360,210,1110,210,1110,960,360,960,360,960,360,960,360,210,1110,210,1110,960,360,960,360,960,360,960,360,960,360,210,1110,210,1110,960,360,210,1110,210,1110,210,1110,960,360,210,1110,210,2250,210,1110,210,1110,960,360,210,1140,180,1110,960,360,960,360,960,360,960,360,210,1110,210,1110,960,360,960,360,960,360,960,360,960,360,210,1110,210,1110,960,360,180,1110,210,1110,210,1110,960,360,210,1110,210,2250,210,1110,210,1110,960,360,210,1110,210,1110,960,360,960,360,960,360,960,360,210,1110,210,1110,960,360,960,360,960,360,960,360,960,360,210,1110,210,1110,960,360,180,1110,210,1110,210,1110,960,360,210,1110,210,2250,210,1110,210,1110,960,360,210,1110,210,1110,960,360,960,360,960,360,960,360,210,1110,210,1110,960,360,960,360,960,360,960,360,960,360,210,1110,180,1110,960,360,210,1110,210,1110,210,1110,960,360,210,1110,2850,6990;
20;76;DEBUG;Pulses=40;Pulses(uSec)=240,930,810,450,780,450,780,480,840,480,330,990,330,990,840,480,840,510,840,480,840,480,840,510,330,990,330,990,840,480,330,990,330,990,330,990,840,480,330,6990;
Second Try
20;7B;DEBUG;Pulses=202;Pulses(uSec)=0,2580,210,1140,180,1110,960,360,210,1110,210,1110,960,360,960,360,960,360,960,360,210,1110,180,1140,960,360,960,360,960,360,960,360,960,360,210,1110,210,1110,960,360,210,1110,210,1110,210,1110,960,360,210,1140,210,2250,210,1110,180,1110,960,360,210,1110,210,1110,960,360,960,360,960,360,960,360,210,1110,210,1110,960,360,960,360,960,360,960,360,960,360,210,1110,210,1110,960,360,210,1110,210,1110,210,1110,960,360,210,1110,210,2250,210,1140,180,1110,960,360,210,1110,210,1110,960,360,960,360,960,360,960,360,210,1110,210,1110,960,360,960,360,960,360,960,360,960,360,210,1140,180,1110,960,360,210,1110,210,1110,210,1110,960,360,210,1110,210,2250,210,1110,210,1110,960,360,210,1110,210,1110,960,360,960,360,960,360,960,360,210,1110,210,1110,960,360,960,360,960,360,960,360,960,360,210,1110,210,1110,960,360,210,1140,180,1110,210,1140,960,360,210,1110,2850,6990;
20;7C;DEBUG;Pulses=42;Pulses(uSec)=360,930,330,930,810,450,810,450,810,450,810,480,330,990,330,990,840,480,840,480,840,480,840,480,840,480,330,990,330,990,840,480,330,990,330,1020,330,990,840,480,330,6990;
Master Off - switch off everything
First Try
20;7D;DEBUG;Pulses=200;Pulses(uSec)=270,1110,210,1110,960,360,210,1110,960,360,960,360,210,1110,960,360,210,1110,960,360,210,1110,210,1110,210,1110,960,360,960,360,960,360,210,1110,210,1110,210,1110,960,360,210,1110,210,1110,960,360,180,1140,210,2250,180,1110,210,1110,960,360,210,1110,960,360,960,360,210,1110,960,360,210,1110,960,360,210,1110,210,1110,210,1110,960,360,960,360,930,360,210,1110,210,1140,180,1110,960,360,210,1140,180,1110,960,360,210,1110,210,2250,180,1110,210,1140,960,360,210,1110,960,360,960,360,210,1110,960,390,180,1110,960,360,210,1110,210,1110,210,1110,960,360,960,360,960,360,210,1110,210,1110,210,1110,960,360,180,1110,180,1110,960,360,210,1110,210,2250,180,1110,210,1110,960,360,210,1110,960,360,960,360,210,1110,960,360,180,1140,960,360,210,1110,210,1140,210,1110,960,360,960,360,960,360,210,1110,210,1110,210,1110,960,360,210,1110,210,1110,960,360,210,1110,2850,6990;
20;7E;DEBUG;Pulses=38;Pulses(uSec)=870,450,300,930,780,480,300,960,840,480,330,990,330,990,330,990,840,480,840,510,840,510,330,990,330,990,330,990,840,480,330,990,330,990,840,480,330,6990;
Second Try
20;7F;DEBUG;Pulses=200;Pulses(uSec)=270,1110,210,1110,960,360,210,1140,180,1110,960,360,210,1110,210,1110,960,360,210,1140,180,1110,210,1110,960,360,960,360,960,360,210,1110,210,1110,960,360,960,360,210,1110,210,1110,210,1110,960,360,210,1110,210,2250,210,1110,210,1110,930,360,210,1110,210,1110,960,360,210,1110,210,1110,960,360,210,1110,210,1110,210,1110,960,360,930,360,960,360,210,1110,210,1110,960,360,960,360,210,1140,180,1110,210,1110,960,360,210,1140,180,2250,210,1110,210,1110,960,360,210,1110,210,1110,960,360,180,1110,210,1110,960,360,210,1110,210,1110,210,1110,960,360,960,360,960,360,210,1110,210,1110,960,360,960,360,210,1110,210,1110,210,1110,960,360,210,1140,210,2250,210,1110,210,1110,960,360,210,1110,210,1110,960,360,210,1110,210,1110,960,360,210,1110,210,1110,210,1110,960,360,960,390,960,360,210,1110,210,1110,960,360,960,360,210,1110,210,1110,210,1110,960,360,210,1110,2850,6990;
20;80;DEBUG;Pulses=38;Pulses(uSec)=210,450,300,930,330,930,780,450,330,990,330,990,330,990,840,480,840,480,840,480,330,990,330,990,840,480,840,480,330,990,330,990,330,990,840,480,330,6990;
Do you require any further information? Can I assist in other ways?
I Greatly appreciate your help!
Greetings from Germany,
Martin Hase
ledfreak3d
Re: Support Request for SilverCrest 3711A / 113854 power switch
#2 Post by ledfreak3d » 11 Nov 2016, 09:42
Same here
set is currently sold at lidl for around 14 euro's
Domoticz Synology Esp easy Location Netherlands /Hoorn
chrille
#3 Post by chrille » 11 Nov 2016, 12:32
RabbitAtNet wrote:I got myself some cheap remote controlled power switches from LIDL, marketed as SilverCrest 113854 (RCR DS1 3711-A). Unfortunately, they are not yet supported by RFLink - an amazing piece of hard- and software by the way.
Hi, your switches looks remarkable similar to the ones mentioned in my post here viewtopic.php?f=10&t=2088
- Jan
Jan Chrillesen, Denmark
RabbitAtNet
#4 Post by RabbitAtNet » 11 Nov 2016, 14:24
Could be. I learned later on, that they are made in China and only branded.
I hope, there is a Chance to add support for them.
ledfreak3d
#5 Post by ledfreak3d » 14 Nov 2016, 14:54
any idea support team ?
Stuntteam
Site Beheer
#6 Post by Stuntteam » 14 Nov 2016, 15:44
It is using a scramble protocol, we are working on it.. but it takes time
RabbitAtNet
#7 Post by RabbitAtNet » 15 Nov 2016, 07:52
Hi Stuntteam,
if a remote and a switch help, I will gladly send you a set. Just drop a postal address by me. (Mail / PM / reply)
Thanks alot for your efforts.
Martin
Stuntteam
Site Beheer
#8 Post by Stuntteam » 18 Nov 2016, 17:11
Thanks for the offer but that is not needed.
We are real close to a full solution...!
(For silvercrest, globaltech, unitec and various other brands)
popperchris
#9 Post by popperchris » 17 Nov 2020, 13:24
Good Day all
i wil bring this to the Top
I have ordert an RFLink Gateway and have this Devices at Home.
If there any News to support this Switches ??
Christoph
Stuntteam
Site Beheer
#10 Post by Stuntteam » 18 Nov 2020, 13:19
Supported since release 45..
popperchris
#11 Post by popperchris » 18 Nov 2020, 13:30
I have 3 "Silvercrest RCR DS1 3711-A" and on my RFLink Device is the latest R48 Load installed.
When i press a Key on RemoteControll RCT DS1 CR-A i don't see any Message in Domoticz and when i Trace the Messages in the Loader i see Messages like this:
20;84;DEBUG;Pulses=202;Pulses(uSec)=30,2640,930,480,900,510,90,1260,900,510,90,1230,930,510,840,510,870,510,840,510,870,510,870,510,90,1260,900,480,90,1230,900,480,120,1230,120,1230,150,1230,930,480,900,510,90,1230,150,1230,150,1230,150,1230,150,2400,930,480,870,510,90,1230,900,480,90,1230,930,510,870,480,870,510,870,480,870,510,840,510,60,1230,930,510,90,1230,900,480,90,1230,120,1260,120,1230,930,480,870,510,90,1260,120,1260,120,1230,150,1230,150,2400,930,480,900,480,90,1230,930,510,90,1230,930,510,870,510,870,510,870,480,870,510,870,510,60,1230,900,480,90,1230,900,510,90,1260,120,1230,150,1230,930,480,870,540,60,1230,120,1230,150,1230,150,1230,150,2400,930,480,900,510,90,1260,870,480,90,1230,900,510,870,480,900,510,840,510,870,510,870,480,90,1230,900,510,90,1230,930,480,90,1230,150,1230,150,1230,930,480,900,510,60,1260,120,1230,150,1260,120,1260,2850,6990;
Stuntteam
Site Beheer
#12 Post by Stuntteam » 18 Nov 2020, 14:33
I see you already mailed in your log.
Some of your buttons are recognized, it will take a while to analyze.
