Hi!
Ok, I've tried but I can't seem to get this working.
I've used the mqtt helper but no joy.
Anyone got a few step by step idiot instructions perchance?
Mqtt gpio control from domoticz
Re: Mqtt gpio control from domoticz
It's the length of the Domoticz MQTT messages.
See the changes in this branch (I'm also running the build in Platformio, instead of the Arduino IDE): https://github.com/ToniA/ESPEasy
Without Platformio, you need to hardcode the value of MQTT_MAX_PACKET_SIZE in the PubSubClient.h, and use the same value here: https://github.com/ESP8266nu/ESPEasy/bl ... er.ino#L49
I'm now using 384 bytes, that seems to be enough.
Ah many thanks
I thought I'd downloaded the libs and the pubsub was "patched" already as mentioned in other posts - that's what I get for assuming!
Cheers
Cheers
Can you use MQTT topic to control a device?
I am trying to control a relay with MQTT helper.
Thanks for any advice!
