Temperature and humidity values from ESP8266 are not seen in Domoticz temperature widget
Posted: 28 Nov 2016, 17:06
I received my ESP8266 with BME280 sensor I connected to Domoticz running on a Raspberry pi2.
I see the temp, humidity & barometer values properly updated on ESP8266 and sent to my Raspberry over JSON.
I also see on Domoticz, the temperature graphic is properly recording the temp & humidity values over the time: All is good so far but the issue is with the temperature widget itself not providing the latest temp & humidity values (on the top-right side of the widget) : Do you know what shall be done to fix it ?
