Hello EveryOne.
Posted: 01 Nov 2015, 23:56
Hello EveryOne,
My firt name is Gabriel.
I develop my domotic with Domoticz.
I've tried wired systems, 433Mhz and NRF24L01. But I don't know if my haouse was hunted, but nor DI.O (chaccon systems) they don't work perfectly.
So, I've decided to use a comfortabe network system : WIFI.
And the ESP8266 Be !!
With EspEasy & Domoticz, I can make a beautyful domotic system.
But I'm a mad developper and I already have Modified EspEasy :
- Correction for the Dallas 18B20 and add the resolution choice
- Add a relay plugin, for use with normal relay and Low state actived relay.
- working , to develop a plugin for the shift register 74HC595, but this task need to modify the core of EspEasy (add a third pin to the device structure)
Is there an other version than the R38 ? (before I' send to you my work)
Thank you a lot for your work.
Best regards
Gabriel
Best regards
Gabriel
