Not without some excitement I just realized the price for dual band GSM / GPRS modules
on aliexpress dropped to less than US$ 2.00 including shipping!
Just US$ 1.50 / free shipping and fixed antenna: http://s.click.aliexpress.com/e/i6mamuj
And one for US$ 2.22 / free shipping with an ipx / u.fl connector and external antenna
http://s.click.aliexpress.com/e/byJAa6e
Here's the full command reference:
http://www.avislab.com/blog/wp-content/ ... s_V3.0.pdf
Prepaid card, GSM module and a sonoff wifi switch/relais and you have a complete solution for less than US$ 8.00 !!
These run on 3.3V, provide a serial port and are configured by common AT commands.
Sounds ideal for ESP easy. How can I make use of them with an ESP module? I'd like to
trigger a switch with a SMS.
Can this be accomplished with just a set of rules?
ultra cheap GSM / GPRS module and ESP easy?
Re: ultra cheap GSM / GPRS module and ESP easy?
Just today, I found this one on banggood:
SONOFF® DIY WIFI Long Distance Power Monitor Remote Control Switch For Smart Home Support 2G/3G/4G Network
http://www.banggood.com/de/SONOFF-DIY-W ... 812201503M
This is basically, what I thought of in my previous post. Probably someone from itead is reading this forum
afaik the Sonoff POW device does NOT support GSM connection... I can guess what banggood write is wrong!
Hmmm, I thought it is a new product... But now that you mention it, I had a closer look at the pcb and there is indeed no gsm module visible.
