Hi, how do I integrate ESP Easy into FHEM ?
many thanks
ESP Easy into FHEM; MQTT
Re: ESP Easy into FHEM; MQTT
At this topic. The problem is that there is no basic mqtt support, so that pushes only the values, so hopefully soon, if someone can code it
http://www.esp8266.nu/forum/viewtopic.php?f=6&t=137
I now tried it with mqtt to fhem. That works a little. I get this in fhem (when using the domotiqz mqtt)
start {"idx":2,"nvalue":0,"svalue":"19.96;74.00;0"}
2015-11-08 20:46:52 transmission-state incoming publish received
I get this as value: {"idx":2,"nvalue":0,"svalue":"19.96;74.00;0"}
Is there a way to only get: 19.96 74.00 or T 19.96 H 74.00
Than it should be simple to get it working
Users browsing this forum: Ahrefs [Bot] and 37 guests
