i ordered a longrange Reader from aliexpress, looks like its generally working.
It beeps at start and also recognizing a tag.
but the (probably) Wiegang-Signal is not recognized by ESPeasy.
(espEasy ver147 on wemos mini d1 and nodemcu ver1 boards. both dont work)
In the past i managed succesfully to get the Wiegand-signal from my fingerprint-Reader.
The fingerprint-reader is now perfectly working over 1/2 year. (espEasy ver145, wemods mini d1 board)
I dont know exactly how to debug this hardware/software issue.
i put a simple oscilloscope on the D0 and D1 wires, and i can see Waves coming in.
Looks like always the same pattern for the same Tag.
I show, what i have. Greatly appreciate any hint to go on from here to get this working with ESPeasy...
(i am somehow a noob... )
RFid reader - Wiegand - Bug with noise-detection?
- wiegand.png (38.37 KiB) Viewed 5180 times
- wiegand-org.png (88.31 KiB) Viewed 5180 times
- frame_24_delay-0.2s.gif (22.83 KiB) Viewed 5184 times
- frame_25_delay-0.2s.gif (22.15 KiB) Viewed 5184 times
- ezgif.com-optimize-200.gif (199.91 KiB) Viewed 5185 times
- em002.png (149.22 KiB) Viewed 5186 times
Re: RFid reader - Wiegand - Help needed
i got it working. with an arduino-leonardo.
i used this code "HID RFID Reader Wiegand Interface (2012)"
from here: http://forum.arduino.cc/index.php?topic=128639.0
i decodes wiegand 26bit (sometimes not).
but in espeasy nothing showed up.
maybe some good developer sees differences/improvements for the ESPeasy code?
would like to hear something positive...
- wiegand-ardu.png (12.43 KiB) Viewed 5165 times
Re: RFid reader - Wiegand - Bug with noise-detection?
i splitted the plugin 008 (rfid-wiegand) out from the esp-source (ver147, core 2.3.0),
and let i run as a simple sketch on my wemos mini d1 (ver2.1).
instantly when i disable the noise-detection, i got a key-result. this works
i am somwhow a noob, so i cannot imagen what must be changed in the source, to get the wiegand-reader more bullet proof.
(my fingerprint-wiegang on the other door is still just fine with the original code of espeasy )...
any help appreciated...
- esp-wiegand2.png (62.26 KiB) Viewed 5158 times
i disabled the noise-detection in espeasy source ver 147 and get normal readings...
i dont understand the reset-loop...
start-condition for bitcount=0,prev=0 is true -> noise
but when the bitcounter increments, prev will get this value in the loop...
and than noise-dection triggers immediately ... hmm?
there must be some other thoughts after this...
at the moment it working without the noise-detection...
maybe a dev can comment on this? or confirm a bug?
how do i see, if it is considered as a bug?
- wiegand-noise.png (24.75 KiB) Viewed 5156 times
