GPIO-09 problem?
Posted: 12 Nov 2015, 20:10
If I use the GPIO-09 port from the dropdown menu I get all sort of problems.
I troubleshoot it first intensively but come back to this portnumber causing problems only sofar on a ESP 8266-201.
Problems are when I choose this port and click SUBMIT the browser blocks.
After a while the browser kicks in again and shows 9 out of 10 times on the port used GPIO-02 as the 09 was not accepted.
However when it shows the port GPIO-09 in use, the ESP201 keep rebooting after a while.
When I remove the GPIO-09 port when it is reachable the ESP201 becomes stable again.
Attched the message that was captured in the serial monitor.
Does any one has the same problem?
Paco
Paco
