Lightwave mood switch error
hi!
I'm trying to use the lightwave mood switch with latext domoticz beta but when pressing any of the mood buttons I get an error in the domoticz log:
E.G
Error: RFLink: Unhandled switch command: MOOD=01
Error: RFLink: Unhandled switch command: MOOD=02
Error: RFLink: Unhandled switch command: MOOD=03
How do we use these buttons?
E.G
Re: Lightwave mood switch error
Is it something that has to be compiled/added to Domoticz?
Well.. I have no idea what to connect it to inside Domoticz..
Nor me lol!
I assume domoticz would need to be coded to link it to switches?
How about instead you change rflink to send switch commands instead of "mood" commands? That would be much quicker to be implemented than waiting for domoticz update
Many thanks William for implementing this
Hi, just registered on the forum as I've got my RFLink board working along my Domoticz set up.
Domoticz does support the mood controller properly using the RFXTRX433 interface (you can find info about this elsewhere), but the problem seems to be with the RFLink.
Cherowley, I'm new so I don't understand your comment of <<many thanks for implementing this WIlliam>>. Is William the person who may implement, or has this been done?
Check your mail..
Looking at the Domoticz source code it is expecting the following when the Group Off and Group 1 etc buttons are pressed on the Lightwave mood controller:
e.g. light5_sOff
Does this make sense to any of the RFLink developers??
https://github.com/CZ-NIC/domoticz-turr ... XNames.cpp (line 1212 onwards)
e.g. light5_sOff
case sTypeLightwaveRF:
bHaveGroupCmd=true;
bHaveDimmer=true;
maxDimLevel = 32;
llevel = (int)float((100.0f / float(maxDimLevel))*atof(sValue.c_str()));
switch (nValue)
case light5_sOff:
lstatus="Off";
case light5_sOn:
lstatus="On";
case light5_sGroupOff:
lstatus="Group Off";
case light5_sMood1:
lstatus="Group Mood 1";
case light5_sMood2:
lstatus="Group Mood 2";
case light5_sMood3:
lstatus="Group Mood 3";
case light5_sMood4:
lstatus="Group Mood 4";
case light5_sMood5:
lstatus="Group Mood 5";
It is unrelated and the issue was fixed a while ago already.
Users browsing this forum: Ahrefs [Bot] and 13 guests
