I have a weather station Excelvan WH3080 with solar, this set is working on 868Mhz. (Simular Fineoffset sets are WH1080/WH1081, and many others)
http://www.excelvan.com/product-g_64.html
Decoding by RFLink_v1.1_r45 is working perfect for; Temperature, Humidity, Wind strength, Wind direction, Rain
Question; - Is it possible to decode/activate the data for UV-index and Light-brightness (Lux)?
The data in domoticz is recognized and identified with protocol "DKW2012".
Ps; pressure is not transmitted by WH3080 transmitter it is in the console, because i am not using the console for reading out data the pressure
is given by BMP280 connected to a SparkFun ESP8266 Thing wifi, and going into Domoticz as Dummy.
The most important reason not to use the console for reading out data is the unreliable behaviour of USB inside the console!
(USB is hanging/blocking data read-out, once a week a month or every day, this in combination with Raspberry or Windows)
I think many Fineoffset weatherstation users can solve there USB problems to use Domoticz and RFLink.
Thank you in forward,
With kind regards,
WimT
To help decoding the UV-index and Light-Brightness here my RFLink data.
Temp= 1,5 C
Humi= 84%
Wind dir.= SE
Wind= 2,5 km/h
Rain=0
UV=0
Lux=1090
20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R45;
10;version;
20;01;VER=1.1;REV=45;BUILD=09;
10;status;
20;02;STATUS;setRF433=ON;setNodoNRF=OFF;setMilight=OFF;setLivingColors=OFF;setAnsluta=OFF;setGPIO=OFF;setBLE=OFF;setMysensors=OFF;
10;rfdebug=on;
20;03;RFDEBUG=ON;
20;0F;Alecto V5;ID=0039;TEMP=813b;RAIN=7e00;BAT=OK;
20;10;DEBUG;Pulses=174;Pulses(uSec)=480,840,420,870,420,870,390,870,420,870,390,900,390,870,390,840,1410,840,420,870,1350,870,1380,870,1380,870,1380,840,1410,870,1380,900,1380,870,1380,840,420,870,1380,870,1380,870,1380,840,420,870,390,870,1380,840,1410,840,420,870,420,870,390,870,420,870,390,900,1380,870,420,870,1380,840,420,870,1380,840,420,900,1380,840,1410,870,1380,900,1350,870,1380,870,1380,870,1350,840,1410,870,420,840,1410,870,1380,870,1380,870,1380,840,1410,870,1380,870,1380,870,390,870,1380,870,1350,900,1350,840,1410,840,1410,870,1380,840,1410,870,390,840,1410,870,1350,870,390,900,390,870,390,870,390,870,1380,900,1380,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,840,420,840,420,870,1350,900,1350,900,390,840,1380,840,1410,840,1410,840,420,870,1380,870,1380,6990;
20;11;DKW2012;ID=0001;TEMP=000f;HUM=84;WINSP=0018;WINGS=0018;RAIN=0768;WINDIR=0006;
20;12;DEBUG;Pulses=57;Pulses(uSec)=150,1440,540,210,150,1290,180,2250,150,3330,210,3630,240,2220,90,3120,90,6420,150,810,90,1170,90,1410,180,1860,180,1170,210,390,120,1560,60,6660,300,2550,300,2250,240,1710,120,420,120,2070,120,4500,120,1530,210,600,60,1140,450,270,150,1350,6990;
20;13;DEBUG;Pulses=24;Pulses(uSec)=750,300,90,240,510,300,330,330,90,900,210,300,570,450,150,270,60,300,210,330,210,180,60,6990;
20;14;DEBUG;Pulses=126;Pulses(uSec)=480,900,450,930,390,960,390,930,420,960,390,900,420,900,1410,930,390,930,420,960,390,900,1440,930,1380,930,390,930,390,930,390,900,1410,930,1380,930,390,960,1350,930,1350,930,1380,870,1440,930,1380,930,390,900,1410,930,420,930,1380,930,390,960,1350,930,390,930,1380,900,1410,930,1380,900,1380,900,1410,930,1380,900,1410,930,1380,930,1380,930,1380,930,390,930,1380,930,420,960,1380,900,420,900,1410,930,1350,930,1380,930,420,930,1380,930,1380,930,1380,930,390,930,1380,930,1380,930,390,900,420,930,1380,930,1380,930,390,930,1380,930,390,6990;
20;15;Alecto V5;ID=0039;TEMP=813b;RAIN=7e00;BAT=OK;
20;16;DEBUG;Pulses=126;Pulses(uSec)=480,930,390,900,420,930,390,930,420,930,420,930,420,930,1380,930,420,930,420,930,420,930,1380,930,1380,900,420,930,420,930,420,930,1350,930,1380,930,390,900,1410,930,1380,930,1380,930,1380,900,1410,930,390,930,1380,930,390,870,1440,930,420,930,1380,930,390,960,1350,870,1440,930,1380,930,1380,930,1380,900,1410,930,1380,930,1380,930,1380,930,1380,870,450,930,1380,900,450,930,1380,930,390,900,1410,930,1380,960,1350,930,420,930,1380,900,1410,930,1380,930,420,930,1380,900,1410,930,420,930,390,930,1380,930,1380,930,390,930,1380,930,390,6990;
20;17;Alecto V5;ID=0039;TEMP=813b;RAIN=7e00;BAT=OK;
20;18;DEBUG;Pulses=174;Pulses(uSec)=450,870,420,870,390,870,390,840,420,870,420,870,390,870,390,840,1410,870,390,840,1410,870,1380,870,1380,870,1380,870,1380,870,1380,870,1380,840,1410,810,450,870,1380,870,1380,840,1410,870,390,870,420,870,1380,840,1440,870,390,870,390,870,390,870,420,870,1380,840,1410,870,420,870,1380,870,420,900,1380,870,420,870,1380,870,1380,870,1380,870,1380,870,1350,900,1380,870,1380,870,1380,870,1350,870,390,870,1380,870,1380,840,1410,870,1380,840,1410,870,1380,870,420,840,1410,840,1410,840,1410,840,1410,870,1380,870,1380,840,1410,870,390,840,1410,870,1410,870,390,870,420,870,420,840,420,900,1350,870,1380,840,1410,840,1410,870,1380,840,1410,900,1350,870,1380,870,390,840,420,840,1380,900,390,870,390,870,390,870,1380,870,420,900,1350,840,1410,870,390,6990;
20;19;DKW2012;ID=0001;TEMP=000e;HUM=84;WINSP=000c;WINGS=0018;RAIN=0768;WINDIR=0006;
20;1A;DEBUG;Pulses=67;Pulses(uSec)=240,1500,300,840,150,330,360,1860,120,1440,90,3540,240,420,150,2010,270,1050,180,420,150,1170,60,300,120,3720,90,390,210,1770,180,330,120,690,390,390,60,1200,240,1470,240,990,630,1200,120,660,120,1470,120,1020,210,1350,150,420,120,1560,210,360,90,810,150,1830,450,810,90,3630,6990;
20;1B;DEBUG;Pulses=34;Pulses(uSec)=150,5340,60,2760,120,900,60,2550,270,1080,90,1500,360,180,330,900,330,2730,360,450,180,1290,300,180,300,1110,450,330,150,1080,450,300,240,6990;
20;1C;DEBUG;Pulses=122;Pulses(uSec)=210,540,150,5580,60,270,90,1410,90,690,120,1560,210,330,90,1260,60,660,150,1980,120,1560,270,330,180,1230,90,810,120,1230,270,420,90,1080,150,660,90,1590,300,4380,330,180,270,1620,210,60,150,2280,120,1830,120,1740,240,3090,30,1200,300,1950,150,2970,120,2100,90,1890,120,2190,390,1560,240,2550,150,2160,180,1470,120,390,180,120,60,1350,300,2070,180,2190,90,2550,300,5430,180,570,180,2010,150,1950,150,1500,300,600,60,1170,120,660,180,1050,150,510,210,1290,330,330,120,1350,180,1320,150,5490,240,330,30,6180,120,6990;
20;1D;DEBUG;Pulses=66;Pulses(uSec)=300,660,30,1140,60,5130,120,2310,120,2730,270,3120,180,3600,90,1440,360,1800,60,6660,180,1770,180,1530,120,1410,150,630,60,2550,120,360,90,4860,90,1890,150,1890,150,180,60,1260,240,570,120,960,120,90,150,1500,120,450,210,1680,30,150,210,120,30,1710,150,2670,90,1620,120,6990;
Weatherstation WH3080 Excelvan (Fineoffset) missing UV and LUX
Re: Weatherstation WH3080 Excelvan (Fineoffset) missing UV and LUX
Excelvan WH3080 ont breekt UV en Lux in Domoticz.
Wim T schreef een uitgebreid stuk over het uitvallen van de data in de Exelvan WH3080, ik Roel B doe het maar in het Nederlands om da ze mij geen Engels aangeleerd hebben in de jaren 50 van de vorige eeuw.
trouwens wel een handicap.
Ik heb het zelfde probleem, met geen UV en Lux weergave. Nu ook overgestapt op Domoticz middels rflink . Dit draait zeer stabiel en overzichtelijk met veel meer mogelijkheden. alleen is het jammer dat op deze manier de UV en Lux waarde ontbreekt.
Zou hier een oplossing voor zijn?
Hierbij mijn rflink data.
Temp= 1,7 C
Humi= 83%
Wind dir.= SE
Wind= 0,5 km/h
Rain=0
UV=0
Lux=0
10;version;
10;status;
20;03;Alecto V520;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R45;
10;version;
10;status;
20;03;Alecto V5;ID=0050;TEMP=813b;RAIN=0000;BAT=OK;
20;04;Alecto V5;ID=0050;TEMP=813b;RAIN=0000;BAT=OK;
20;05;DKW2012;ID=0036;TEMP=0011;HUM=83;WINSP=0000;WINGS=000c;RAIN=0888;WINDIR=0006;
20;06;DKW2012;ID=0036;TEMP=0011;HUM=83;WINSP=0000;WINGS=000c;RAIN=0888;WINDIR=0004;
20;07;Alecto V5;ID=0050;TEMP=813b;RAIN=0000;BAT=OK;
20;08;Alecto V5;ID=0050;TEMP=813b;RAIN=0000;BAT=OK;
20;09;DKW2012;ID=0036;TEMP=0011;HUM=83;WINSP=0000;WINGS=000c;RAIN=0888;WINDIR=0008;
10;rfdebug=on;
20;0A;RFDEBUG=ON;
20;0B;DEBUG;Pulses=126;Pulses(uSec)=480,960,390,930,420,930,420,960,390,960,390,930,420,960,1380,930,390,960,390,960,390,960,1380,930,390,960,1380,960,390,960,1380,960,1380,960,1380,930,1380,930,1410,960,1380,960,1380,960,1380,960,1380,960,390,960,1380,930,390,960,1380,930,420,960,1380,960,390,960,1380,960,1380,930,1380,960,1380,960,1380,960,1380,960,1380,960,1380,960,1380,930,1380,930,1380,960,1380,960,1380,960,1380,960,1380,960,1380,930,1380,960,1380,960,1380,960,1380,960,1380,930,1380,960,1380,930,1380,960,390,960,1380,960,390,960,390,960,390,960,390,960,390,960,420,6990;
20;0C;Alecto V5;ID=0050;TEMP=813b;RAIN=0000;BAT=OK;
20;0D;DEBUG;Pulses=126;Pulses(uSec)=480,960,390,960,390,960,390,960,390,960,390,960,420,960,1380,960,390,960,390,930,420,960,1380,930,420,960,1380,900,420,960,1380,960,1380,960,1380,960,1380,960,1380,930,1380,930,1380,930,1380,960,1380,960,390,960,1380,930,420,960,1380,930,390,960,1380,960,390,960,1380,960,1380,960,1380,960,1380,930,1410,930,1380,930,1380,960,1380,960,1380,960,1380,960,1380,930,1380,960,1380,960,1380,930,1380,960,1380,960,1380,930,1380,960,1380,960,1380,930,1380,960,1380,960,1380,930,1410,960,390,960,1380,930,390,960,390,960,390,960,390,960,390,960,420,6990;
20;0E;Alecto V5;ID=0050;TEMP=813b;RAIN=0000;BAT=OK;
20;0F;DEBUG;Pulses=174;Pulses(uSec)=450,900,390,870,390,900,390,870,390,870,390,870,390,870,390,900,1350,870,390,870,1380,870,1380,900,1350,870,390,900,390,900,1350,900,390,870,390,900,1350,870,1380,870,1350,900,1350,870,390,870,390,900,1350,900,390,900,1350,870,1350,870,1380,870,1350,900,390,900,1350,900,390,900,1350,870,390,900,1350,900,1350,870,390,870,390,900,1350,900,1350,900,1350,870,1380,870,1380,870,1380,900,1350,870,1380,900,1350,900,1350,870,1350,900,1350,900,1350,870,1380,870,1380,900,390,870,1350,900,1350,900,1350,870,1380,870,1380,870,1350,870,420,870,1380,870,390,900,390,870,1380,900,390,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,900,1350,840,1410,870,420,900,1350,900,390,870,1350,870,1380,870,390,900,1350,870,1380,870,1380,870,1380,900,1350,870,390,6990;
20;10;DKW2012;ID=0036;TEMP=0011;HUM=83;WINSP=0000;WINGS=000c;RAIN=0888;WINDIR=0010;
20;11;DEBUG;Pulses=126;Pulses(uSec)=480,960,390,960,390,930,420,960,390,930,420,930,420,960,1380,930,390,930,420,960,390,960,1380,960,390,960,1380,930,420,960,1380,960,1350,960,1380,960,1380,960,1380,930,1380,960,1380,960,1380,960,1380,960,390,960,1380,960,390,960,1380,960,390,960,1380,930,420,960,1380,960,1380,960,1380,960,1380,960,1380,960,1380,960,1380,960,1380,960,1380,960,1380,960,1380,960,1380,960,1380,960,1380,960,1380,960,1380,930,1380,930,1410,960,1380,960,1380,960,1380,930,1410,960,1380,930,1410,930,390,960,1380,930,390,960,390,960,390,960,390,960,390,960,390,6990;
20;12;Alecto V5;ID=0050;TEMP=813b;RAIN=0000;BAT=OK;
20;13;DEBUG;Pulses=126;Pulses(uSec)=480,930,390,960,390,960,390,960,390,960,390,960,390,960,1380,930,420,960,390,960,390,960,1380,930,420,960,1380,960,390,960,1380,960,1380,960,1380,960,1380,960,1380,960,1380,930,1380,960,1380,960,1380,960,390,930,1380,930,420,960,1380,960,390,960,1380,960,390,960,1380,960,1380,930,1410,960,1380,960,1380,960,1380,930,1380,930,1410,960,1380,960,1380,960,1380,960,1380,960,1380,960,1380,960,1380,960,1380,960,1380,960,1380,960,1380,930,1410,960,1380,960,1380,960,1380,930,1380,960,390,960,1380,930,390,960,390,960,390,960,390,960,390,930,420,6990;
20;14;Alecto V5;ID=0050;TEMP=813b;RAIN=0000;BAT=OK;
20;15;DEBUG;Pulses=174;Pulses(uSec)=450,900,390,870,420,870,390,900,390,900,390,870,390,900,390,870,1350,870,390,900,1350,870,1350,870,1410,870,390,900,390,870,1380,870,390,870,420,870,1380,900,1350,870,1380,870,1350,870,390,900,390,870,1350,870,390,900,1350,870,1380,870,1350,870,1380,900,390,900,1350,870,390,870,1350,870,390,900,1350,870,1380,900,390,900,390,870,1380,870,1380,900,1350,900,1380,870,1380,870,1380,900,1350,870,1350,900,1350,870,1380,900,1350,870,1380,870,1350,900,1350,900,1350,900,390,870,1380,900,1350,900,1350,870,1380,900,1350,870,1380,870,390,870,1380,870,390,870,390,870,1350,900,390,870,390,900,1350,900,1350,900,1350,900,1350,870,1380,900,1350,870,1380,900,390,900,1350,870,420,870,1350,900,1350,870,390,900,1350,870,1380,870,1380,870,1380,870,1380,870,390,6990;
20;16;DKW2012;ID=0036;TEMP=0011;HUM=83;WINSP=0000;WINGS=000c;RAIN=0888;WINDIR=0010;
Temp= 1,7 C
Humi= 83%
Wind dir.= SE
Wind= 0,5 km/h
Rain=0
UV=0
Lux=0
10;version;
10;status;
10;version;
10;status;
10;rfdebug=on;
20;0A;RFDEBUG=ON;
