Support for PZEM 004T Energy monitor
ut1545
Re: Support for PZEM 004T Energy monitor
#101 Post by ut1545 » 08 Jul 2018, 18:26
I'm trying to compile last ESPeasy V2.0 release (ESPEasy-2.0-20180510) but I'm getting the same errors as #71 http://www.letscontrolit.com/forum/view ... 585#p22585.
Did anyone solve this issue? How to compile this plug in under the latest releases of ESPeasy software?
Thanks in advance,
asking
#102 Post by asking » 12 Jul 2018, 16:04
Raspi_0x00 wrote:
27 Mar 2018, 11:24
Problem solved. Works grate!!! The problem was that my PCB was configured for use UART0 (GPIO1..3).
When I changed do 13-15 everything is OK.
But I wonder why the Voltage measurement is such unstalble ( I get -1 in most readings).
Any ideas? Update rate is 1min
i am also getting same error -1 randomely inbetween 1 minute readings... did you solved it ? what was the issue ? can you share ?
aleph0
#103 Post by aleph0 » 13 Jul 2018, 08:55
I have two pzem connected to my wemos ; I've also got this problem on one of them :-( I never understood what was the cause, I simply ignore wrong reading in domoticz. Not very satisfying, but enough for my purpose
asking
#104 Post by asking » 13 Jul 2018, 18:01
aleph0 wrote:
13 Jul 2018, 08:55
Do you think its related to software library of arduino ? or TTL 5V to 3.3V Converter issue ?
aleph0
#105 Post by aleph0 » 13 Jul 2018, 18:18
asking wrote:
13 Jul 2018, 18:01
I don't think so as the 2 pzem are connected on the same module, so same software library ; I also don't use any converters and connected 5V to GPIO directly. This is not conventional but I wanted to make a test and it's working 24/7 since last november, so I think it's safe enough ;-)
It's something related to either the pzem itselft, or the GPIO used to connect them. But as my setup is now kinda "in production" I cannot make any tests anymore :-(
I plan to buy some more for another equipment, it'll give me another testing possibility. But it'll be in a month or so
miki_tnt
#106 Post by miki_tnt » 14 Aug 2018, 11:37
Dear all,
i have tried to compile the _P171_PZEM-004T.ino plugin (last version 8 months ago) and I get some errors and warnings:
lib/AS_BH1750/AS_BH1750A.cpp: In member function 'bool AS_BH1750A::startMeasurementAsync(TimeFuncPtr)':
lib/AS_BH1750/AS_BH1750A.cpp:518:7: warning: unused variable '_lastResult' [-Wunused-variable]
int _lastResult = -1;
lib/AS_BH1750/AS_BH1750A.cpp: In member function 'bool AS_BH1750A::delayExpired()':
lib/AS_BH1750/AS_BH1750A.cpp:533:19: warning: comparison between signed and unsigned integer expressions [-Ws
ign-compare]
if (timestamp < _lastTimestamp)
lib/AS_BH1750/AS_BH1750A.cpp:536:45: warning: statement has no effect [-Wunused-value]
delayTime = MAX_U_LONG - _lastTimestamp + timestamp;
lib/AS_BH1750/AS_BH1750A.cpp:542:24: warning: comparison between signed and unsigned integer expressions [-Ws
ign-compare]
return (delayTime >= _nextDelay);
ESPEasy-mega-20180809/src/_P171_PZEM-004T.ino: In function 'boolean Plugin_171(byte, Eve
ntStruct*, String&)':
ESPEasy-mega-20180809/src/_P171_PZEM-004T.ino:69:68: error: too many arguments to functi
on 'void addFormNote(const String&)'
addFormNote(string, F("SoftSerial: 1st=RX-Pin, 2nd=TX-Pin"));
ESPEasy-mega-20180809/src/WebServer.ino:2788:6: note: declared here
void addFormNote(const String& text)
Could anybody help me with these issues?
#107 Post by TD-er » 14 Aug 2018, 13:56
The signed/unsigned warning can be ignored.
The errors in WebServer.ino are also quite simple to resolve.
The functions used there in the "PLUGIN_WEBFORM_LOAD" case no longer need the first parameter "string"
So just remove that parameter:
Change it into:
addFormNote(F("SoftSerial: 1st=RX-Pin, 2nd=TX-Pin"));
papperone
#108 Post by papperone » 14 Aug 2018, 18:46
I need to review this plugin in order to move it to the standard repository...
honestly still same issue, lack of time to improve it making it working with multiple devices (e.g. to monitor multiple lines or 3-phase AC).
miki_tnt
#109 Post by miki_tnt » 16 Aug 2018, 19:15
yes, you are right, I already corrected the error regarding addFormNote function, but I am getting more errors after the warning
ESPeasySoftwareSerial.cpp:(.iram.text+0xd4): multiple definition of `sws_isr_0()'
.pioenvs/normal_ESP8266_1024/lib010/SoftwareSerial/SoftwareSerial.cpp.o:SoftwareSerial.cpp:(.iram.text+0xf8):
first defined here
.pioenvs/normal_ESP8266_1024/libc99/ESPEasySoftwareSerial/ESPeasySoftwareSerial.cpp.o: In function `sws_isr_1
ESPeasySoftwareSerial.cpp:(.iram.text+0xec): multiple definition of `sws_isr_1()'
.pioenvs/normal_ESP8266_1024/lib010/SoftwareSerial/SoftwareSerial.cpp.o:SoftwareSerial.cpp:(.iram.text+0x110)
: first defined here
.pioenvs/normal_ESP8266_1024/libc99/ESPEasySoftwareSerial/ESPeasySoftwareSerial.cpp.o: In function `sws_isr_2
ESPeasySoftwareSerial.cpp:(.iram.text+0x104): multiple definition of `sws_isr_2()'
.pioenvs/normal_ESP8266_1024/lib010/SoftwareSerial/SoftwareSerial.cpp.o:SoftwareSerial.cpp:(.iram.text+0x128)
collect2: error: ld returned 1 exit status
*** [.pioenvs/normal_ESP8266_1024/firmware.elf] Error 1
========================== [ERROR] Took 59.91 seconds ==========================
Environment normal_ESP8266_1024 [ERROR]
#110 Post by TD-er » 16 Aug 2018, 21:49
Hmm, that's very strange, I only got those errors when building the latest ESP32 code.
Try to run a "clean" build first before recompiling.
miki_tnt
#111 Post by miki_tnt » 16 Aug 2018, 23:00
Thank you very much.
Yes, it is very strange. I have cleaned the project and compiled it again but no luck... I dont understand what it is going on. I am using last mega release.
Any other suggestion will be appreciated.
kind regards,
Dim33
#112 Post by Dim33 » 29 Aug 2018, 00:16
Hello everybody,
My energy measurement is operationnal by following this post and this one http://www.domoticz.com/forum/viewtopic ... 14&t=20820
I use an ESP8266_4096.
But I have a problem :
- if I boot my ESP connected to the PZEM. My ESP doesn't start (no effect if I push on RESET button),
- If I boot my ESP (not connected to the PZEM), this one start normaly and after i can connect the PZEM to the ESP and the Energy measurement is OK.
This problem is painful because if i have a power cut, my Energy measurement does not restart.
Can you help me ?
Thanks in advance.
#113 Post by TD-er » 29 Aug 2018, 13:28
Maybe you connected the sensor to one of the pins needed to indicate the boot-mode?
For example GPIO0, which is connected to the "Flash" button on NodeMCU boards, will put the ESP into flash mode when pressed.
I can imagine the sensor will do the same when connected to that pin.
Dim33
#114 Post by Dim33 » 30 Aug 2018, 22:56
Dim33 wrote:
29 Aug 2018, 00:16
Hello everybody,
Can you help me ?
Thanks in advance.
I modified the GPIO pin : GPIO-12 and 13 instead of GPIO-14 and 15 and all is OK.
pppp33
#115 Post by pppp33 » 30 Aug 2018, 23:17
Hi there,
I've got a PZEM an tried to compile, but got same "multiple definition" error, as miki_tnt :
.pioenvs\test_ESP8266_4096\lib46c\ESPEasySoftwareSerial\SoftwareSerial.cpp.o: In function `sws_isr_0()':
SoftwareSerial.cpp:(.iram.text+0xd0): multiple definition of `sws_isr_0()'
.pioenvs\test_ESP8266_4096\lib46c\ESPEasySoftwareSerial\ESPeasySoftwareSerial.cpp.o:ESPeasySoftwareSerial.cpp:(.iram.text+0xd4): first defined here
.pioenvs\test_ESP8266_4096\lib46c\ESPEasySoftwareSerial\SoftwareSerial.cpp.o: In function `sws_isr_1()':
SoftwareSerial.cpp:(.iram.text+0xe8): multiple definition of `sws_isr_1()'
.pioenvs\test_ESP8266_4096\lib46c\ESPEasySoftwareSerial\ESPeasySoftwareSerial.cpp.o:ESPeasySoftwareSerial.cpp:(.iram.text+0xec): first defined here
.pioenvs\test_ESP8266_4096\lib46c\ESPEasySoftwareSerial\SoftwareSerial.cpp.o: In function `sws_isr_2()':
SoftwareSerial.cpp:(.iram.text+0x100): multiple definition of `sws_isr_2()'
.pioenvs\test_ESP8266_4096\lib46c\ESPEasySoftwareSerial\ESPeasySoftwareSerial.cpp.o:ESPeasySoftwareSerial.cpp:(.iram.text+0x104): first defined here
.pioenvs\test_ESP8266_4096\src\ESPEasy.ino.cpp.o:(.text._Z21Plugin171_ReadVoltagev+0x8): undefined reference to `PZEM004T::voltage(IPAddress const&)'
.pioenvs\test_ESP8266_4096\src\ESPEasy.ino.cpp.o: In function `Plugin171_ReadVoltage()':
ESPEasy.ino.cpp:(.text._Z21Plugin171_ReadVoltagev+0x25): undefined reference to `PZEM004T::voltage(IPAddress const&)'
.pioenvs\test_ESP8266_4096\src\ESPEasy.ino.cpp.o:(.text._Z21Plugin171_ReadCurrentv+0x0): undefined reference to `PZEM004T::current(IPAddress const&)'
.pioenvs\test_ESP8266_4096\src\ESPEasy.ino.cpp.o:(.text._Z21Plugin171_ReadCurrentv+0x1d): undefined reference to `PZEM004T::current(IPAddress const&)'
.pioenvs\test_ESP8266_4096\src\ESPEasy.ino.cpp.o:(.text._Z19Plugin171_ReadPowerv+0x0): undefined reference to `PZEM004T::power(IPAddress const&)'
.pioenvs\test_ESP8266_4096\src\ESPEasy.ino.cpp.o:(.text._Z19Plugin171_ReadPowerv+0x1d): undefined reference to `PZEM004T::power(IPAddress const&)'
.pioenvs\test_ESP8266_4096\src\ESPEasy.ino.cpp.o:(.text._Z20Plugin171_ReadEnergyv+0x0): undefined reference to `PZEM004T::energy(IPAddress const&)'
.pioenvs\test_ESP8266_4096\src\ESPEasy.ino.cpp.o: In function `Plugin171_ReadEnergy()':
ESPEasy.ino.cpp:(.text._Z20Plugin171_ReadEnergyv+0x1d): undefined reference to `PZEM004T::energy(IPAddress const&)'
.pioenvs\test_ESP8266_4096\src\ESPEasy.ino.cpp.o:(.text._Z10Plugin_171hP11EventStructR6String+0x1c): undefined reference to `PZEM004T::PZEM004T(unsigned char, unsigned char)'
.pioenvs\test_ESP8266_4096\src\ESPEasy.ino.cpp.o:(.text._Z10Plugin_171hP11EventStructR6String+0x20): undefined reference to `PZEM004T::setAddress(IPAddress const&)'
.pioenvs\test_ESP8266_4096\src\ESPEasy.ino.cpp.o: In function `Plugin_171(unsigned char, EventStruct*, String&)':
ESPEasy.ino.cpp:(.text._Z10Plugin_171hP11EventStructR6String+0x14e): undefined reference to `PZEM004T::PZEM004T(unsigned char, unsigned char)'
ESPEasy.ino.cpp:(.text._Z10Plugin_171hP11EventStructR6String+0x15b): undefined reference to `PZEM004T::setAddress(IPAddress con
Is there any suggestion to overcome this issue ?
Perhaps something changed in libraries, etc. in the last months ?
Thanx & Regards
Paolo
GieBek
#116 Post by GieBek » 30 Nov 2018, 23:34
Would it give advice to throw the plugin into the latest software. PZEM has been working very well for me for half a year but I miss some features from the new software.
Greetings.
#117 Post by grovkillen » 30 Nov 2018, 23:38
Please open an issue for it on GitHub and ask the maintainer to add it as a PR.
GieBek
#118 Post by GieBek » 01 Dec 2018, 00:01
Thank you very much for your answer.
I did what you wrote.
Greetings.
GieBek
lyovav
#119 Post by lyovav » 10 Dec 2018, 12:13
hnaeem07
#120 Post by hnaeem07 » 23 Dec 2018, 13:25
I am not getting correct value for Watts when i did the calculation, example as below
Actual reading from meter = 232.20 Volts , 2.89 Amps, 665.00 Watts, 1311707.00 KWH
232.20 x 2.89 = 671.06 Watts, but in the meter it shows 665.00, can i know why its not accurate ?
Thanks in advance. :D
Domosapiens
#121 Post by Domosapiens » 23 Dec 2018, 16:11
Real power and apparent power ?
https://en.wikipedia.org/wiki/Electric_power
antikiller_bm
#122 Post by antikiller_bm » 17 Jan 2019, 21:21
I also have some problem with building this project
I have two builds ESPEasy_mega-20181231 and latest with changed Softwareserial library
ESPEasy_mega-20181231 compiles without error only if espsoftwareserial-3.2.3 used
20190110 compiles with new ESPEasySerial library also without any errors
But both firmwares always shows me 0.00, even old version mega 2.00 dev
I think that is not a hardware problem, wifi-iot firmware works fine, but with the hardware serial.
Im already tried to change GPIOs to another with the same result.
Interesting that is no voltage measuring in the log, A W Wh only
serjkru
#123 Post by serjkru » 30 Mar 2019, 22:14
Hi guys,
I got working on one esp-12f 6 of PZEM 004T. Probably I could connect up to 8 PZEM in the same time to one esp-12f.
The idea was to use many PZEM 004T on one esp-12f without using address of each one. I connected each one in parallel with RX, TX, and GND. For select with whom I am communicating right now I decided to use esp-12f ports.
If anyone interested I would share my schematic and plugin.
Thank you.
RobertM
#124 Post by RobertM » 31 Mar 2019, 09:53
I'm interested - can you send me plugin ?
Also you can share public ;)
AndrewJ
#125 Post by AndrewJ » 31 Mar 2019, 21:27
Hi serjkru,
I'm very interested, too! This seems to have a good fit with the direction I'd like to take, which is to measure power use in each (main) circuit in my house.
I'd be very happy if you could share your schematic and plugin, please. :)
Thanks in advance,
Andrew
serjkru
#126 Post by serjkru » 01 Apr 2019, 03:10
Hi guys,
Thank you for your interest.
There is a pdf how to connect them
Plugin for PZEM-004T.(I used one from playground but change it a lot)
Also I had to change Software serial ESPeasySoftwareSerial.cpp because original didnot work.
I think I did not mess something.
If you have a question, do not hesitate!
PZEM-004T.zip
(693.54 KiB) Downloaded 179 times
serjkru
#127 Post by serjkru » 01 Apr 2019, 03:13
If someone use OpenHab there is sample:
items
Number   Sensor_Laundry_Voltage "Laundry [%.1f V]"  <voltage>(Home) [ "LaundryVoltage" ] { mqtt="<[myhome:/HouseVACMeter/PZEM_1/Voltage(V):state:default]" }
Number   Sensor_Laundry_Current "Laundry [%.1f A]"  <current>(Home) [ "LaundryCurrent" ] { mqtt="<[myhome:/HouseVACMeter/PZEM_1/Current(A):state:default]" }
Number   Sensor_Laundry_Power   "Laundry [%.1f W]"  <power>  (Home) [ "LaundryPower" ]   { mqtt="<[myhome:/HouseVACMeter/PZEM_1/Power(W):state:default]" }
Number   Sensor_Laundry_Energy  "Laundry [%.1f Wh]" <energy> (Home) [ "LaundryEnergy" ]  { mqtt="<[myhome:/HouseVACMeter/PZEM_1/Energy(Wh):state:default]" }
sitemap
Frame label="House Sensors" icon="house"{
	Text label="Power management" icon="power" {
		Text label="Laundry" icon="energy" {
			Text item=Sensor_Laundry_Voltage        label="Voltage"    icon="energy"
			Text item=Sensor_Laundry_Current        label="Current"    icon="energy"
			Text item=Sensor_Laundry_Power          label="Power"      icon="energy"
			Text item=Sensor_Laundry_Energy         label="Energy"     icon="energy"
serjkru
#128 Post by serjkru » 01 Apr 2019, 03:25
Hi guys,
I have developed many projects for my smart house but not sure when I should post them.
If someone lives in US or Canada, you might be interested in WiFi wall switch.
My idea was to use jst regular wall switch and put all elecrtonics right under switch button. You can see it on the photoes:
It is dimmable switch with two buttons.
I created plugin for it as well and connected to OpenHab.
Also I developed two version of Humidity/Temperature/Pressure devices. I use BME280 as sensor.
One of them looks like usb stick for remoute mouse or keyboard another one a little bit bigger.
usb BME280.png (2.84 MiB) Viewed 2710 times
DaveS
#129 Post by DaveS » 01 Apr 2019, 18:29
@serjkru.
Please could you post the wiring schematic for the PZEM-004 modules to the ESP-8266 module,I do not see the pdf file.
Looking at the wiring picture posted earlier, you are sequentially supplying power to the PZEM modules and taking readings to send to openhab.
Good idea to save IO pins !
serjkru
#130 Post by serjkru » 02 Apr 2019, 02:18
My appologies,
I updated my post viewtopic.php?p=36179#p36179
Thank you
DaveS
#131 Post by DaveS » 02 Apr 2019, 19:49
Cheers mate.
Very nice work !
xury
#132 Post by xury » 03 Apr 2019, 14:43
Very good idea.
What is the reading time of all sensors?
How often can you read?
serjkru
#133 Post by serjkru » 04 Apr 2019, 02:12
xury wrote:
03 Apr 2019, 14:43
Very good idea.
In my project its read every minute.
There is no problem to read each 10 second or so.
tfelleg
#134 Post by tfelleg » 23 Apr 2019, 18:57
Hi Guys!
Thank you Serjkru for firmware. I tried with two device (Wemos D1 4 MB, and Wemos D1 mini 4 MB), but I did not found the Voltage & Current (AC) in device list.
Where did I go wrong?
Thank you
Best
Tamas
RobertM
#135 Post by RobertM » 23 Apr 2019, 19:44
"P183-Voltage & Current (AC) - PZEM-004T" almost at the end of the list of devices ;)
tfelleg
#136 Post by tfelleg » 23 Apr 2019, 20:17
I did not found.
Here is the picture about the last devices.
Thank you
Best
Tamas
RobertM
#137 Post by RobertM » 23 Apr 2019, 20:32
Try with attached file
firmware_PZEM004T multiple.zip
(584.94 KiB) Downloaded 109 times
tfelleg
#138 Post by tfelleg » 23 Apr 2019, 20:53
RobertM, you are GENIUS! :)
It works!
Thank you very much! :)
Best
Tamas
serjkru
#139 Post by serjkru » 26 Apr 2019, 22:09
tfelleg wrote:
23 Apr 2019, 20:53
It works!
Best
Tamas
Could you please answer on some questions:
What binary did you use when you was not able to find the plugin?
Did you use a binary file which I posted?
Thank you.
xury
#140 Post by xury » 03 Jun 2019, 13:29
serjkru Why did you removed R15?
And why you swap R17 to 120 Ohm except 510 Ohm?
It would not be enough to solder 1k resistor as in the picture?
Jay74
#141 Post by Jay74 » 19 Jun 2019, 20:17
Hi all,
I'm using the firmware provided by serjkru and is working fine (pzem-004t v2.0)...good job :D
I have another question: is it possible to use the PZEM-004T V3.0 ? The firmware on the board has changed and I think the protocol is different, so no communication with esp.
The last board I got is 3.0 :(
Anyone is working with that kind of board ?
Thank you
Gianluca
oliver92
#142 Post by oliver92 » 25 Jun 2019, 10:54
papperone wrote:
26 Jun 2017, 12:57
Aliki wrote:
26 Jun 2017, 12:47
papperone, You already very long wait... Since January 2017. :) June already comes to an end... ;)
Somebody can already has made support ?
Can developers will add support PZEM-004T in the next release ESPEasy?
I know, oredered from China, usually 2/3 months but this was was probably lost and reordered in May.... Sorry but in Italy we have a not so good postal service :o
you should have used USPS service, it is very good
Now USPS employees can use liteblue portal (liteblue usps gov) to get all the benefits.
xury
#143 Post by xury » 15 Jul 2019, 10:38
Hi I ordered PZEM-004 and got V3.0 version.
This version have new mdbus MTU protocol.
Someone tried develop a plugin?
