Hi All,
After searching for a long time i still have not found an answer; "how to pair the SHS-53000 radiator valve to my RP/RFLink running on Domoticz".
I tried all logical possibilities:
1. Adding the remote by learning (Learn Light/Switch). The remote is detected, but controlling it, gives no result on the valve.
2. Maualy creating a RFLink Device (with the command line). The remote is also detected, but again controlling it, gives no result on the valve.
3. Adding the remote manually (Manual Light/Switch). Same problem.
4. Tried the command line in the RFLink Loader. According to the instruction https://www.domoticz.com/forum/viewtopic.php?t=13742 Again, same problem.
Somehow the signal / command from the RFLink does not reaches the valve. Can anybody help?
Thanks in advance.
Adding Smartwares SHS-53000
Domoticz on Raspberry Pi 3 with RFLink Gateway (433 MHz en NRF 2,4GHz) and EnOcean USB 300.
Re: Adding Smartwares SHS-53000
Hi There,
Here's another guy struggling in exactly the same way to get his SH5-RDV-A (SHS-53002) Smartwares Valves alive in Domoticz. After spending a couple of hours, doing the same as the previous poster, and much more -> No result!
Since I have two of these valves which were supposed to be supported by Domoticz/RFLink (R38 and up), it would be nice to get this issue solved. I've found many users on the web, reporting similar issues regarding this type of valves, that were left behind without any solution (like Bart above). If there is any thing I can do to help / contribute, please react. Many thanks in advance.
Running Domoticz v3.7422 on RPi3B / RFLink R46 as a main system, but same result as Domoticz v3.5877 on Windows10 / 2nd RFLink on R46.
If you guys post this questions in the rightplace, RFLink unsupported devices. : https://www.letscontrolit.com/forum/viewforum.php?f=10
Chances are that Stuntteam gives an answer or solution.
This forum is for ESPEasy and related issues.
I have 2 SMARTWARES SHS-53000. I try to connect on my DOMOTICZ through RFLINK (V47.8) without any success.
There is someone can help me step by step.
Trying for about 1 year for peering it, but never success for yer...
