This is my first post so please move if it's not the right place.
I recently bought and soldered together the RFlink and it works like a breeze it just flies with all my AC type switches (and even some of my neighbour temp sensors).
It works exactly expected and needed another remote control so I bought one on Aliexpress that should be supported (EV1527 chip)
https://www.aliexpress.com/item/Hot-1pc ... 33888.html
Before I reset the remote I managed to receive one switch into Domoticz. (The remote was working)
I reset all buttons (By holding two of them together for a few seconds) and I can no longer receive any signal values in Domoticz.
Now I managed to create a new EV1527 switch with the following sequence "20;07;EV1527;ID=029d69;SWITCH=04;CMD=ON" in "Create RFlink device" under Hardware.
It looks like I can send that signal from within Domoticz - But is it the right one for this remote control?.
I'm not really sure how accurate the manual is on how to code the remote says exactly: (Many errors)
The on - off part is no longer than a few milliseconds and there are no apparent signal that the remote entered copying status.Copying: place the product correctly before copying. Place the original remote control and copying remote control on the desk. Use right hand to press the copying remote control until LED is on - off. indicating it enters copying status. Use left hand to press the key of original remote control. The fast clicking of remote control indicates success in copying. The copying method is the same for several keys.
I have tried to keep the remote next to RFlink and "click the orignal remote" (in Domotics) but I don't seem to manage to copy the code to the remote.
My question is am I doing this right? Is the code right, and Is this how the remote is supposed to be coded?
What am I doing wrong here?
Many thanks for your input and for sharing your experience.
