Re: Oregon OSV3 protocol - wrong ID
Posted: 03 Feb 2017, 08:11
by Synthex
Here are frames.
For each :
1) rfxcom frame
2) rfxcom decoded
3) rflink pulses
4) rflink decoded
0A520221FA0200BE390069
Packettype = TEMP_HUM
subtype = TH2 - THGN800,TGHN801,THGR810
channel 2
Sequence nbr = 33
ID = 64002 (FA02)
Temperature = 19 °C
Humidity = 57
Status = Normal
Signal level = 6 -72dBm
Battery = OK
20;C4;DEBUG;Pulses=178;Pulses(uSec)=30,420,420,420,420,390,420,390,420,420,420,420,420,390,420,420,390,420,420,420,420,420,420,390,420,420,420,390,420,390,420,420,390,420,420,420,420,420,420,390,420,390,420,420,420,420,420,900,900,900,900,390,420,420,390,420,390,420,390,900,420,390,420,390,900,900,900,900,420,390,420,390,420,390,900,900,420,390,900,900,420,390,420,390,900,900,900,420,390,420,390,420,390,420,420,900,420,390,420,390,900,900,420,390,420,390,420,390,930,900,420,390,900,420,390,900,420,390,420,390,420,390,420,390,420,390,420,390,900,390,420,420,420,900,930,900,900,900,420,390,420,390,420,390,420,390,420,390,900,420,390,900,900,900,900,900,420,390,420,390,420,390,420,390,420,390,420,390,420,390,420,390,420,390,420,390,420,6990;
20;C5;Oregon TempHygro;ID=28FA;TEMP=00be;HUM=57;HSTATUS=0;BAT=OK;
0A520222E803004C580369
channel 3
Sequence nbr = 34
ID = 59395 (E803)
Temperature = 7,6 °C
Humidity = 88
Status = Wet
Battery = OK
20;C6;DEBUG;Pulses=178;Pulses(uSec)=480,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,840,930,840,900,360,420,360,420,360,420,360,420,870,420,360,420,360,900,840,900,870,420,360,420,360,420,360,900,870,900,360,420,840,420,360,420,360,420,360,420,360,900,870,900,360,420,360,420,840,420,360,420,360,420,360,420,360,930,360,420,870,900,360,420,360,420,870,420,360,420,390,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,900,840,420,360,420,360,900,840,420,360,900,360,420,360,420,360,420,360,420,360,420,360,420,840,900,870,420,360,420,360,900,360,420,840,420,360,420,360,420,360,270,6990;
20;C7;Oregon TempHygro;ID=28E8;TEMP=004c;HUM=88;HSTATUS=3;BAT=OK;
115A020488C20000000436000151594C7A79
Packettype = ENERGY
subtype = ELEC3 - OWL CM180
Sequence nbr = 4
ID = 35010 (88C2)
Count = 0
Instant usage = 1078 Watt
total usage = 25304579,5 Wh
Signal level = 7 -64dBm
Battery = OK
20;6D;DEBUG;Pulses=220;Pulses(uSec)=510,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,840,900,840,420,360,420,360,930,360,420,840,420,360,420,360,420,360,420,360,420,360,900,840,420,360,450,360,420,360,900,360,420,870,420,360,420,360,930,840,420,360,420,360,930,360,420,360,420,840,420,360,420,360,420,360,930,840,420,360,450,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,930,840,900,360,420,360,420,360,420,840,420,360,420,360,930,360,420,840,420,360,900,840,900,840,420,360,900,360,420,840,930,840,900,840,420,360,420,360,900,840,930,840,900,840,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,930,840,420,360,420,360,420,360,900,360,420,840,420,360,420,360,930,840,420,360,900,360,420,360,420,6990;
20;6E;Oregon CM180;ID=008C;WATT=0436;KWATT=01821e03;
115A022088C2000000029300015159ABF679
Packettype = ENERGY
Sequence nbr = 32
ID = 35010 (88C2)
Count = 0
Instant usage = 659 Watt
total usage = 25304688,8 Wh
Battery = OK
20;C2;DEBUG;Pulses=218;Pulses(uSec)=510,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,870,930,840,420,360,420,360,930,360,420,840,420,360,420,360,420,360,420,360,420,360,930,840,420,360,420,360,420,360,900,360,420,840,420,360,420,360,930,840,420,360,420,360,900,360,420,840,420,360,930,840,930,840,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,900,360,420,840,900,360,420,360,420,360,420,360,420,360,420,840,930,840,900,870,900,360,420,840,420,360,930,360,420,840,930,840,930,840,420,360,420,360,930,840,900,840,900,840,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,930,360,420,360,420,840,930,360,420,840,420,360,930,360,420,840,420,360,420,360,900,840,420,6990;
20;C3;Oregon CM180;ID=008C;WATT=0293;KWATT=01821e70;
