Hello, I have Domoticz set up with MQTT (Mosquitto) and I added simple switch. When I turn it on using /control?cmd=GPIO,5,1, I see it goes on in Domoticz. However when I turn it then off in Domoticz, I see the message in domoticz/out with correct idx and nvalue, but ESP seems to be ignoring that message doing nothing to the GPIO.
The switch is set as:
I tried setting up the Output - (Domoticz MQTT helper), just trying blind luck:
But that didn't help.
Is there a way to react on messages from Domoticz? Or do I have to use the HTTP action on ON/Off?
Reacting on MQTT message from Domoticz
Re: Reacting on MQTT message from Domoticz
For simple on/off that's the most easy thing to do.Is there a way to react on messages from Domoticz? Or do I have to use the HTTP action on ON/Off?
But do I have to? Or is there an other way?NietGiftig wrote: For simple on/off that's the most easy thing to do.
It's the length of the Domoticz MQTT message. In my own branch I'm using PlatformIO to build ESPEasy, so that I can have global #define's in the ini file.
With Arduino IDE, you need to hardcode longer MQTT buffer support into pubsubclient and Controller.ino.
Ahh, thanks. Good to know.ToniA wrote:It's the length of the Domoticz MQTT message.
I also found there's a chance of infinite loop, if two messages are published quickly after each other before Domoticz processes these:
- ESP: GPIO,5,1 (sends MQTT payload to Domoticz)
- ESP: GPIO,5,0 (sends MQTT payload to Domoticz)
- Domoticz responds in domoticz/out setting to ON, where ESP picks it up and turns it ON (step 2 turned it off) - so back to step 1.
- Domoticz responds in domoticz/out setting to OFF, where ESP picks it up and turns it OFF (previous step turned it on)
