http send being truncated in rules
Hello everyone, I'm just starting with ESPEasy and Domoticz, and I can't seem to put a http send in the rules to send a change in local output state when I use a local input to change it to Dometicz:
This is what I put in:
on local#switch do
if [lightstate#switch]=0
gpio,2,1
SendToHTTP 192.168.0.243,8080,/json.htm?type=command¶mm=switchlight&idx=10&switchcmd=On
gpio,2,0
SendToHTTP 192.168.0.243,8080,/json.htm?type=command¶mm=switchlight&idx=10&switchcmd=Off
But once I hit submit, this is what happens:
on local#switch do
gpio,2,1
gpio,2,0
I'm guessing I'm doing something whrong, but I have no idea what !!
Anyone have any suggestions?
on local#switch do
gpio,2,1
gpio,2,0
on local#switch do
gpio,2,1
gpio,2,0
Re: http send being truncated in rules
try using a different browser
Try to change the format of the rules line
changing it into
SendToHTTP 192.168.0.243,8080,/json.htm?type=command&idx=10&switchcmd=On¶mm=switchlight
that might help.
changing it into
that might help.
The problem seems to be that '¶' is replaced by '¶' when the rules are saved.
This has been noted many times before!
Domoticz, Sonoff, ESP32
Westcott wrote:The problem seems to be that '¶' is replaced by '¶' when the rules are saved.
Is anyone aware of a workaround/fix?
I have the same issue, works the same way with both Chrome and IE
Any info or feedback on this would be appreciated.
+1
Workaround: Make sure that the "param" valuepair is the first in the list.
I use it like this:
I use it like this:
sendtohttp 192.168.0.8,8080,/json.htm?param=udevice&type=command&idx=229&svalue=%eventvalue%
this issue should now be fixed in the latest git-version. https://github.com/letscontrolit/ESPEasy/issues/231
Yes now it works.
