Hello from Shropshire, UK
Posted: 14 Feb 2017, 18:29
by AndrewJ
Hello forum,
I've recently discovered the ESPeasy firmware, what a fantastic project!
I've installed it on 3 nodemcus so far, and will be doing more. Currently working on an AC current /power plugin.
AndrewJ.
Re: Hello from Shropshire, UK
Posted: 01 Mar 2017, 13:31
by keithhamilton
Hi Andrew
Good to meet you.
How are you getting on with your AC current / power plugin?
I am working on Infrared control Web App that stores button data and would like to include current monitoring so that I know if TV etc is on.
Keith
Posted: 01 Mar 2017, 13:38
by bobbybeans
omg I signed up for this forum specifically for help with an IR plugin! do you have a github for that?
because the current r034 irtx plugin can't send raw codes and when I send the hex codes it sends it differently than its written, or maybe I am just being dumb (very possible)
Posted: 02 Mar 2017, 21:42
by AndrewJ
Hi @Keith Hamilton,
I've got it *partly* working as a plugin. It gives out what seem sensible power readings to mqtt, but for some reason it doesn't display them in the devices page. I need to do some testing to check accuracy too. At that stage I'll put it on github for other people to try out.
Hth, Andrew.
Posted: 31 Mar 2017, 10:24
by keithhamilton
Hi Andrew
Hope you are well.
How is your test progressing. What hardware did you use?
Keith
Posted: 31 Mar 2017, 12:58
by AndrewJ
Hi Keith,
Just getting back to this after a period where other things got in the way. I'm going to start a separate topic about it, as I'm having a few difficulties at present.
Andrew
