it is possible a LCD and a BMP085 to operate paralel?
Many thanks!
LCD and BMP085 operate paralel?
Re: LCD and BMP085 operate paralel?
no problem
no problem
okay thank you , and how do I connect them? LCD SDA, SCL and BMP085 SDA, SCL together on esp pin for example GPIO4 SDA and GPIO5 SCL?
Many thanks!
Many thanks!
u could set the ports under the tab Hardware.
Yes, but make sure the display has no pull up resistors to +5volts.tobia wrote:okay thank you , and how do I connect them? LCD SDA, SCL and BMP085 SDA, SCL together on esp pin for example GPIO4 SDA and GPIO5 SCL?
Many thanks!
