mvn77
#1
Post
by mvn77 » 17 Mar 2017, 18:47
Help! It is necessary to reset the variable "TotalCount" every day (Device - Pulse Counter)
Rules -
On Clock#Time=All,20:00 do
[rain#TotalCount] = 0
On Clock#Time=All,8:00 do
Rule does not work
log-
Fri Mar 17 20:00:02 2017: 192.168.0.51: <7>ESP Unit: 0 : EVENT: Clock#Time=Fri,20:00
Fri Mar 17 20:00:02 2017: 192.168.0.51: <7>ESP Unit: 0 : ACT : 1.40 = 0
mvn77
#2
Post
by mvn77 » 18 Mar 2017, 09:14
Bad decision -
reboot
reboot
Do you have any other suggestions?
toffel969
#3
Post
by toffel969 » 18 Mar 2017, 10:54
Have you tried TaskValueSet command?( store variable in Dummy device, and 2.. task) then read dummy rather than sensor value
Like
On pulse#total do
TaskValueSet 2,1,[pulse#total]
End on
On Clock #Time=all, 20:00 do
TaskValueSet 2,1,0
mvn77
#4
Post
by mvn77 » 18 Mar 2017, 12:01
I thought. But with the next record, he will write down the "pulse#total" value into the variable.
How much I understood in rules it is impossible to work with variables - to subtract, to multiply ....
paxi
#5
Post
by paxi » 18 Mar 2017, 18:04
mvn77 wrote: ↑18 Mar 2017, 09:14
Bad decision -
reboot
reboot
What happens? Bootloop for a minute I guess. In this case a workaround is to set a timer and reboot when it's 20:01.
You
can do basic calculations in rules like this:
TaskValueSet 4,3,[test#a]-[test#b]
So store your a bias-pulsecount once a day in one variable, substract that from the actual pulsecount into another dummyvalue and publish this.
mvn77
#6
Post
by mvn77 » 19 Mar 2017, 12:06
Thank you!!!!!!
mvn77
#7
Post
by mvn77 » 19 Mar 2017, 18:59
Can create a rule for calculating RAINRATE for DOMOTICZ? RAINRATE = amount of rain in last hour
paxi
#8
Post
by paxi » 20 Mar 2017, 00:27
Always a joy.
"Hourly rain" would be easy with the same principle using a timer that triggers every 60 minutes but that would only provide a measurement for every full hour. An instant (every minute) "last 60 minutes" would require to store 60 values and awefullly hacky rules- too much for espeasy - as mentioned earlier I don't use domoticz nor know its cababilities but think this kind of statisic is definately a job for the controler.
You could compromise something with 15 minute intervalls using the 4 availible values of a single dummy device, still a lot of fiddling though.
novembre62
#9
Post
by novembre62 » 10 May 2019, 15:49
Hi!
I take these old posts to be helped:
sorry but I'm very inexperienced
I would like to reset my pulse counter variable at 00:01 every day
"Total" with the TaskValueSet rule
"Sensors": [
"TaskName": "counter",
"Count": 0.00,
"Total": 2591.75, <<<<<<<<<<<< THIS
"Time": 27470.00
"TaskName": "outside temperature",
"Temperature": 21.19
but I don't understand how to do it ... someone can help me
thank you
Post
by grovkillen » 10 May 2019, 16:47
Use rule and the command TaskValueSet.
Post
by grovkillen » 10 May 2019, 16:58
On Clock#Time=All,00:01 Do
TaskValueSet,TaskNo,ValueNo,Value
EndOn
If your device is on task number 4 (as an example) and the total is on value number 3 your rule would be looking like this:
TaskValueSet,4,3,0
EndOn
And that is already explained further up in this topic.
novembre62
#12
Post
by novembre62 » 10 May 2019, 19:48
Thanks for the reply.
I apologize if I ask a trivial question, but I am inexperienced ..
how can I then have the new value as a json output?
Post
by grovkillen » 10 May 2019, 20:06
To trigger the value change event you can do the same but change the command to TaskValueSetAndRun.
novembre62
#14
Post
by novembre62 » 10 May 2019, 21:35
I entered the "TaskValueSetAndRun" command with rule
On Clock # Time = All, 21: 28 do
TaskValueSetAndRun, 1,2,0
but the "Total" value of the pulser counter device does not change
Post
by grovkillen » 11 May 2019, 10:12
Don't have spaces in the event name!
novembre62
#16
Post
by novembre62 » 11 May 2019, 14:26
there are no spaces
in image my device
https://drive.google.com/file/d/1ZiPhKf ... dgXug/view
then
On Clock#Time=All,12:09 Do
TaskValueSetAndRun,1,2,0
EndOn
it's correct ?
the "TaskValueSetAndRun" command, should change the "Total" value of my device to 0 at the set time and then continue counting until the next set time ?????
Do not do anything else ... I read in the tutorial rules that a Dummy Device needs ... but I don't know how to do it
I use the value of my "Total" device as a JSON output, which I read in a monitoring system (Metern) in this way
http://192.168.1.150/json?tasknr=1
It is a water meter and I would like to reset the value every day at 00:01
I apologize for my inexperience
Post
by grovkillen » 11 May 2019, 14:35
Maybe try the TaskValueSet followed be a TaskRun instead...
TaskValueSet,1,2,0
TaskRun,1
Post
by grovkillen » 11 May 2019, 14:38
If that isn't working it might be a bug.
novembre62
#19
Post
by novembre62 » 11 May 2019, 14:41
I tried but it doesn't work
log:
60867434: ACT: TaskValueSet, 1,2,0
60867446: ACT: TaskRun, 1
60867475: EVENT: counter # Count = 0.00
60867503: EVENT: counter # Total = 344.75
60867536: EVENT: counter # Time = 1245007.00
60876994: WD: Uptime 1011 ConnectFailures 0 FreeMem
novembre62
#20
Post
by novembre62 » 11 May 2019, 14:42
Total value does not change
Post
by grovkillen » 11 May 2019, 14:43
Ok, I guess that TaskValueSet is the command not working then. Until we have fixed it you may do a reboot once at 00:01?
novembre62
#22
Post
by novembre62 » 11 May 2019, 14:45
that's what I already do, reboot at 00:01, but I'd like to avoid this
novembre62
#23
Post
by novembre62 » 11 May 2019, 14:47
in the post above I read:
TaskValueSet 4.3, [test # a] - [test # b]
but I didn't understand what to do
Post
by grovkillen » 11 May 2019, 14:57
The other example you posted is to show how you can do calculations. That's not what you're asking about. It's a bug and we should fix it. But in the meantime, do the reboot.
Post
by TD-er » 11 May 2019, 21:44
There still is a space in the line of the rules
And the suggestion made by Jimmy to do the reboot will probably not work (anymore) in the more recent builds.
I (quite recently) fixed a bug, which does now keep track of the last values of plugins after a reboot. (as long as the board was powered)
So I expect the plugin to continue counting after a crash or reboot.
Domosapiens
#27
Post
by Domosapiens » 12 May 2019, 01:06
My suggestion,
at 00.01
read the value
and
subtract that value
novembre62
#28
Post
by novembre62 » 23 Aug 2019, 18:51
.....My suggestion,
at 00.01
read the value
and
subtract that value.....
.......I do not know how to do...
I can get help
thank you
