Esp Easy and Wemos Motor Shield
giobbe
#1 Post by giobbe » 21 Mar 2017, 11:08
I would use the Wemos motor shield (https://www.wemos.cc/product/motor-shield.html) with easy esp. I tried to insert the library in esp easy but it does not work. You can help me?
Thank you
Giobbe
krikk
Re: Esp Easy and Wemos Motor Shield
#2 Post by krikk » 21 Mar 2017, 21:53
without coding there is no support for this shield, we have support for the adafruit motorshield v2 currently
..but as this shield is also i2c based it should be pretty simple to write a plugin for it...
giobbe
#3 Post by giobbe » 22 Mar 2017, 09:28
that soon it would be nice make plugin for Wemos Motor Shield,
as it is very common
This is a arduino library: https://github.com/wemos/WEMOS_Motor_Sh ... no_Library
giobbe
#4 Post by giobbe » 04 Apr 2017, 09:08
up
giobbe
#5 Post by giobbe » 11 Apr 2017, 09:33
Re-Up....
:cry:
krikk
#6 Post by krikk » 11 Apr 2017, 10:11
this wont help...
3 option:
  1. do it yourself, doku for development is on the wiki...
  2. find someone who codes it for you...
  3. wait and hope that someone with coding skills and this motorshield write a plugin
giobbe
#7 Post by giobbe » 29 Apr 2017, 23:14
up
giobbe
#8 Post by giobbe » 19 Feb 2018, 16:01
UP
TungstenE2
#9 Post by TungstenE2 » 15 May 2018, 19:12
Hi, did you find a solution?
I would also like to use the wemos motor shield with ESPeasy mega latest build.
thx
TungstenE2
#10 Post by TungstenE2 » 15 May 2018, 19:29
Hi krikk,
I found your Plugin P048_Motorshield_v2.ino when I was searching for setup of Wemos Motorshield with Wemos D1 mini running ESPeasy mega latest version.
Is there a way to use your plugin for Adafruit Motorshield with Wemos Motorshield? If not, is there an other way to use the Wemos Motorshield without dedicated plugin?
I am new to ESPeasy and I am not a developer.
thx Tungsten
https://www.letscontrolit.com/wiki/inde ... lugin_list
TungstenE2
#11 Post by TungstenE2 » 22 May 2018, 21:56
Hi all,
I have set up Wemos D1 mini and Motorshield using latest ESPeasy test version.
Setup up according to Plugin48 documentation using Hex 0x30.
https://www.letscontrolit.com/wiki/index.php/Plugin48
https://wiki.wemos.cc/products:d1_mini_ ... hield#pins
When I send HTTP request, I see the command in log, but motor does not turn.
http://192.168.178.66/control?cmd=Motor ... ckward,200
Any advice would be appreciated.
thx
TungstenE2
#12 Post by TungstenE2 » 24 May 2018, 09:22
There is a fix for the motorshield firmware.
Now the I2C scanner finds the 0x30 device.
https://hackaday.io/project/18439-motor ... rogramming
TungstenE2
#13 Post by TungstenE2 » 27 May 2018, 20:00
good news. wemos motorshield plugin is under development. stay tuned...
TungstenE2
#14 Post by TungstenE2 » 10 Jun 2018, 19:50
added new Plugin for Wemos Motorshield P_078 in Testing
https://github.com/letscontrolit/ESPEasy/pull/1492
TungstenE2
#15 Post by TungstenE2 » 29 Aug 2018, 15:13
Wemos Motor Shield Plugin is now in official mega release!
See wiki:
https://www.letscontrolit.com/wiki/inde ... otorshield
#16 Post by grovkillen » 29 Aug 2018, 15:42
Please move the rules example to the rules tutorial page :)
aussieatlarge
#17 Post by aussieatlarge » 31 Oct 2018, 12:51
I can confirm that the "new" boards (or might be boards purchased from Wemos Aliexpress store) work without flash.
Well kinda. They work just fine with example Arduino sketches.
However, I cannot get them to work with ESPEASY.
WemosMotorShieldCMD, 0, Forward, 30 does nothing. Not even cause the command script to popup like it does whith gpio, 14, 1
Am I missing something?
TungstenE2
#18 Post by TungstenE2 » 31 Oct 2018, 13:39
did you flash ESPeasy testing version? Only in testing version the plugin is included.
just follow the wiki.
aussieatlarge
#19 Post by aussieatlarge » 31 Oct 2018, 14:12
Tungsten
I followed the wiki.
I even flashed an old driver board - the difference between the "new" board and the flashed board is that the new board shows in an I2C search.
When I send the command http://192.168.1.178/control?cmd=WemosM ... Forward,99
i see this in the log WemosMotor: Motor = 1 Direction = forward Speed = 99
motor is connected to B1 B2
power is connected to motorboard.
board works perfectly with example Arduino code.
the only strange thing is that when I create the device I get the error at the top of the screen
Invalid character in names. Do not use ',#[]' or space
Please help. I know I am close. version mega-20181031 dev
TungstenE2
#20 Post by TungstenE2 » 31 Oct 2018, 14:46
can you post error message?
I am using ESP_Easy_mega-20180927_test_ESP8266_4096.bin
And I use A1, A2:
WemosMotorShieldCMD 0 Forward 30
Device Name: WemosDCMotor
trs
#21 Post by trs » 31 Aug 2019, 18:53
There is a 2.0.0 version of the Wemos Motor shield now being sold by Wemos which does not work with ESPEasy.
I guess that’s the Problem aussieatlarge was facing too. It is not possible to flash the motor shield as described, maybe because there is no rts pin anymore that could be connected to 3V?
Has anybody successfully used a Wemos motor shield v2.0.0 with espeasy?
Stefan
trs
#22 Post by trs » 31 Aug 2019, 19:10
Additional info:
Wemos points to a different arduino library for the 2.0.0 shield. And it seems they changed names from Wemos to Lolin.
Wemos motor shield 1.0.0 >>>
https://github.com/wemos/WEMOS_Motor_Sh ... master/src
Wemos Motor shield 2.0.0 >>>
https://github.com/wemos/LOLIN_I2C_MOTO ... master/src
TungstenE2
#23 Post by TungstenE2 » 07 Nov 2019, 13:17
sorry, I can not support on V2 version, but V1 version is still available and should work.
https://de.aliexpress.com/item/32920107053.html
