Hello I flashed ESPEasy v 148 onto Sonoff plugs and I am able to control them via OpenHab2/MQTT; however I would like to be able to manually switch on/off by pressing the little button on the plug; is it possible? If yes, how?
Hereafter my devices config:
These are my rules:
on lightSwitch#Switch do
if [lightState#Switch]=0
gpio,12,0
gpio,12,1
Sonoff Enable button after flashing v 148
Re: Sonoff Enable button after flashing v 148
This is my rule. As you see you only want to check the button state since it will control the relay state. Your rule will never change the relay since the "if" will always see that the relay state is 0. So change if [lightState#Switch]=0 to if [lightSwitch#Switch]=0
on Button#State do
if [Button#State]=0
Publish %sysname%/status,Manual turn off relay
gpio,12,0
gpio,13,1
Publish %sysname%/status,Manual turn on relay
gpio,12,1
gpio,13,0
That made it, thanks!!!
