Ds18b20 temp and relay control via openhab
Posted: 06 May 2017, 11:58
by shenery
Hi everyone. I'm fairly new to espeasy and esp8266.
I have. 6 sonoff switches loaded with espeasy using mqtt with openhab. They work flawlessly with espeasy and I'm really happy with them.
Not I have switches working I would like to create a thermostat that will turn my boiler on and off.
Does anyone have settings I can steal to get the ds18b20 working with mqtt on openhab along with relay.
And also if anyone has sitemap/items examples I could look at?
Kind regards
Steven
Re: Ds18b20 temp and relay control via openhab
Posted: 06 May 2017, 12:44
by toffel969
shenery wrote: 06 May 2017, 11:58 Hi everyone. I'm fairly new to espeasy and esp8266.
Kind regards
Steven
You can even realise this rules and global sync, no need for a controller. I could help with that. Other than that I use domoticz via http, so no idea how to OpenHAB/MQTT
Posted: 07 May 2017, 16:09
by shenery
I have just altered one of my switches with the relay on to include the ds18b20 sensor and ticked global sync. I can now see temperature reading in the log. I will try and add this to my sitemap and items later and see if it works :-)
Posted: 08 May 2017, 04:55
by sheppy
Be sure to add a little difference between turn on and turn off temperature in OpenHAB as the DS18B20 readings can flick between 2 values every time they are read. A rule similar to the one below in OpenHAB should work
Rule "regulate temperature"
when Item MyTemperatureSensorChanged then
if (MyTemperatureSensor.state !=NULL) { // add in any checks after the NULL statement to ensure the reading is valid
if (MyTemperatureSensor.state > 20) {
//Do stuff like turn Heater OFF etc
if (MyTemperatureSensor.state < 19.8) {
//Do stuff like turn Heater ON etc
end
Posted: 08 May 2017, 19:13
by shenery
Hi @sheppy thanks for getting back to me.
I was wondering if you could send me a copy if you sitemap and items so that I can compare with mines.
Kind regards
Steven
Posted: 08 May 2017, 22:50
by sheppy
Hi Steven,
in this case the Items file would read
Number MyTemperatureSensor { mqtt="<[mosquitto:TOPIC/MyTemperatureSensor:state:default]" }
Switch Heater
where "mosquitto" is the actual name of the MQTT Server set in Openhab, and "TOPIC" is the topic set in ESPEasy
The Sitemap would read
Text item=MyTemperatureSensor label="My Temperature Sensor [%.1f C]" icon="temperature"
Switch item=Heater
In this case "1" in [%.1f C" refers to the number of decimal places to be displayed, and "C" refers to the letter "C" appearing after the reading
Posted: 09 May 2017, 08:40
by shenery
Thank you very much for your reply.
I now have my temperature with a heating switch underneath.
Do you know if it is possible to have and up down control switch of the heating temperature? As in turn the relay on or off like a thermostat depending on which temperature you see. A bit like this?
Kind regards
Steven
Posted: 09 May 2017, 08:45
by sheppy
Yes it's very doable, I use something similar to work my Heatpumps. I'll take a look in the morning and give you a few clues, although you might be better putting the question on community.openhab.com
Posted: 10 May 2017, 01:35
by sheppy
Ok, try this
Items file
Number WantedTemperature
Switch Heater
Sitemap file
Setpoint item=WantedTemperature label="Heating Setpoint [%.1f C]" icon="temperature" minValue=17 maxValue=28 step=0.3] // adjust the minValue and maxValue and step to whatever makes sense to you
Switch item=Heater
Rules
"Rule set default temperature"
when System started then {
postUpdate(WantedTemperature, 21)
end
this sets the temperature to something sensible after the system starts and also after this rule is edited, once it has been set and persistence has been added with restore on startup this rule can be disabled
when Item MyTemperatureSensorChanged or Item WantedTemperature changed then
var WT = WantedTemperature.state as Number
if (MyTemperatureSensor.state > WT) {
if (MyTemperatureSensor.state < WT) {
end
Posted: 10 May 2017, 18:56
by shenery
OK so I think I'm nearly there.
I have my sitemap looking not bad and can turn on off the heating but I am having trouble getting the temp to display in openhab. Its reading fine in espeasy log so is working.
I think I need to alter my code slightly.
Posted: 10 May 2017, 18:57
by shenery
Heres the rest of my settings
Posted: 10 May 2017, 20:36
by shenery
I managed to get the temperature reading in openhab. I had the mqtt location wrong.
I have also created a .rules file in openhab which I didn't post before but still when I increase the temp in openhab my heater doesn't go on.
Posted: 10 May 2017, 21:20
by sheppy
If that's the actual rule?
"//Do stuff like turn Heater OFF etc" will need replacing with
"sendCommand(Heater, OFF)"
AND
"//Do stuff like turn Heater ON etc" will need replacing with
"sendCommand(Heater, ON)"
all without the ""
also anything after // is a comment and is for information only
Posted: 10 May 2017, 22:13
by shenery
Ah I see. How do I get my power icon back? The heater has a lightbulb instead of a power icon. Is this because my heater item is set up as a light?
Thanks for all your help by the way. Much appreciated.
Steven
Posted: 10 May 2017, 22:19
by sheppy
Yes, see below for available icons, try using "fire" or "heating" as an icon and the icon will change between ON and OFF
http://docs.openhab.org/addons/iconsets ... eadme.html
Posted: 11 May 2017, 08:49
by shenery
Ok I've tidied things up a bit but I still can't get it to do what I want. When I have the heater on and decrease the temp the relay should switch off right? And switch back on when I increase the temp?
I can turn my heater on and off but now with temperature adjustment.
Posted: 11 May 2017, 09:27
by sheppy
Looking at it on my phone I suspect you have a missing space in the second line, it should read
"when item MyTemperatureSensor changed or item WantedTemperature changed then"
Posted: 11 May 2017, 16:02
by shenery
Its still not working. Here are my items rules and sitemap.
Posted: 12 May 2017, 05:46
by sheppy
OK, lets see what is working.
Change your rules file to read
end
rule "test what is working"
var MT = MyTemperatureSensor.state as Number
logInfo("Testing", "Wanted Temperature is " +WT
logInfo("Testing". "Sensed Temperature is " +MT
end
Now open up openhab.log - if you have Raspbian Jessie and an apt-get installation it is found in /var/log/openhab2 and can be seen live by typing
tail -f /var/log/openhab2/openhab.log for other operating systems and installations please see the openhab documentation
whenever the temperature changes or when you change the requested temperature you should see 2 log entries, the first with the set temperature, and the second with the sensed temperature. If any of these aren't the values you expect then you need to check your items file, and also for the sensed temperature you need to check the device running ESPEasy
Posted: 12 May 2017, 09:15
by shenery
Ok I've checked the log and it is only giving me wanted temperature when I click + or -I don't get any sensed temperature.
Posted: 12 May 2017, 09:32
by sheppy
Sounds like a ESPeasy or mqtt configuration problem, I'm unable to get to my PC for a day or so now, I'd recommend checking those things. When it's working you should see a valid reading in your sitemap that changes if you warm the sensor by warming it with your hand
Posted: 12 May 2017, 22:37
by shenery
Ok here's where I'm at.
I have openhab log working and I can now see sensed temperature
I can see wanted temperate
I can switch my heating switch on and off manually but not with altering the setpoint in the sitemap.
In the log with original rules you sent when I change set point I get wanted temperature changed but I don't see a command for on or off to the switch.
I have attached some screenshots.
Kind regards
Steven
Posted: 12 May 2017, 22:39
by shenery
And here's one of me switching the heating on manually.
Posted: 13 May 2017, 00:10
by sheppy
The purple writing in the screenshot suggests there is a problem with your rules file, and looking at my original rules there was a couple of missing close brackets. Usually I use smarthome designer from the openhab downloads site for my editing, whilst its not perfect, it catches most of these. I'd strongly recommend it for someone new to OpenHAB.
Now we have valid values, change the rules to read this, use copy and delete what is already there. If you get the purple cannot be parsed correctly rule there usually is a typo somewhere. Once it is working add // before each logging statement to stop it filling the logs
end
when Item MyTemperatureSensor Changed or Item WantedTemperature changed then
logInfo("Testing", "Wanted Temperature is " +WT)
logInfo("Testing", "Sensed Temperature is " +MT)
if (MT > WT) { sendCommand(Heater, OFF) }
if (MT + 0.1 < WT) {sendCommand(Heater, ON) }
end
Posted: 13 May 2017, 14:44
by shenery
I tried that and got the same error. I have eclipse installed but haven't really delved that deep in to it yet. Had a look last night and I can see all my files but not sure how to check syntax and stuff like that.
Also what do you mean with adding // before log entries?
Kind regards
Steven
Posted: 14 May 2017, 12:37
by shenery
Not even getting a decent log reading now. Don't know what I've done wrong. When I do log:tail I get endless readings and they go that fast I can hardly read them.
Posted: 14 May 2017, 21:16
by shenery
I managed to get it working at last! :-) worked out how to find errors with eclipse smart home and turns out I had " in the wrong place. It was to the left of the. "Rule instead of rule " regulate temperature.
Thanks for all your help sheppy. I now have a working WiFi thermostat.
Kind regards
Steven
Posted: 15 May 2017, 22:35
by sheppy
Well done! Using the designer is a good idea as a small typo can waste much time when you are new to Openhab. It is a great system once you master it and https://community.openhab.org is a great place to search if you have a problem. ESPEasy also works very well with it
Posted: 16 May 2017, 10:35
by shenery
Yeah. I'll be using eclipse a lot more, now that I know how to use it. Was pulling my hair out a bit but go there in the end. Was a good learning exercise.
Thanks again
Stevenn
Posted: 18 May 2017, 00:34
by sheppy
One other thing I'd recommend is working out how you see the system ending up in future and then planning your MQTT topic tree so it makes sense going forward. For example you could have
Security/ containing the status of doors and windows
Heating/ or
Climate/ for your heater items or maybe extra sub topics make sense such as
Climate/LivingRoom/
Climate/MainBedroom/
Electricity/
Home automation systems have a habit of growing and what seems over complicated now may work out better in future when you are trying to debug an obscure fault.
When debugging you can use a program such as mqtt.fx subscribe to all messages with a simple "#" or subscribe to sub topics such as "Climate/#" or even in the above example "Climate/LivingRoom/#"
The first "/" in the topic tree isn't needed btw so your topic "/StevensLamp/gpio/12" could be simplified to "StevensLamp/gpio/12" as long as both OpenHAB and ESPEasy are changed
Posted: 21 May 2017, 03:13
by waspie
I have a whole bunch of stuff done on this topic I could help you with if I had my laptop up. I'm using many esp and motorized vents to regulate temperature like zoning in every room. I use openhab as well Image
The vent can be open closed or set for heat/cool. In heat or cool it opens or closes as temperature goes up or down depending on how you want it. Then, the use ac and use furnace switches affect a variable. If enough rooms want ac or heat there's another esp that'll turn on the hvav separate of the nest
Also, the readings of the Dallas are awesome, they vary very little. I used to use analog sensors and averaged them over 3 minutes using readings every 10 seconds. With the Dallas I have it send a reading every 3 minutes using a separate esp that's in deep sleep and battery powered away from the vent. The Dallas sensors are rock solid
Posted: 22 May 2017, 17:53
by waspie
HEre are the relevant portions if you want. Any questions, just ask.
nursery items
Number	Nursery_Temperature 		"Nursery Temp	   [%.1f °F]" <temperature>	{mqtt="<[oh2:/NurserySensor/Nursery_Temp/NUR_TEMP:state:default]" }
Number	Nursery_Volts	 			"Nursery Volts	   [%.2f V]" <electric>	{mqtt="<[oh2:/NurserySensor/Nursery_Volt/NUR_VOLT:state:default]" }
Number	VT_Vent_Setpoint_Nursery 	"Nursery Setpoint [%.1f °F]"    <degreesf>
Number	VT_Vent_Mode_Nursery     	"Nursery Vent Control"          <heating>
Switch	FF_Nursery_Vent           	"Nursery Vents"         <fire>          {http=">[OFF:POST:http://192.168.1.151/control?cmd=event,closevent] >[ON:POST:http://192.168.1.151/control?cmd=event,openvent]"}
Number	AVG_Nursery		    		"Nursery Average Temp [%.1f °F]"	<degreesf>
Switch	FF_Nursery_Vents			"Nursery Vents"			<fan>
Number	VT_Nursery_Keepwarm			"Nursery Call Heat"		<fire>
Number	VT_Nursery_Keepcool			"Nursery call cool"		<fan>
Number	NurseryNeedHeat				"Nursery Heat Request"	<fire>
nursery rules (the use furnace / use ac stuff isn't done yet. that's why at least one section is missing. )
rule "Nursery OnOff"
when
    Item VT_Vent_Mode_Nursery changed
then
    // 0="Off", 1="On", 2="Auto"
    if (VT_Vent_Mode_Nursery.state == 0) {
        // heater off
        FF_Nursery_Vents.sendCommand(OFF)
    } else if (VT_Vent_Mode_Nursery.state == 1) {
        // heater on
        FF_Nursery_Vents.sendCommand(ON)
        else{
end
rule "Nursery Vents Status"
when
    Item VT_Vent_Mode_Nursery changed or
    Item VT_Vent_Setpoint_Nursery changed or
    Item Nursery_Temperature changed
then
	if (VT_Vent_Mode_Nursery.state == 2) {
		var Number setpointN = VT_Vent_Setpoint_Nursery.state as DecimalType
		var Number turnOnTempN = setpointN - 0.5
		var Number turnOffTempN = setpointN + 0.5
		var Number tempN = Nursery_Temperature.state as DecimalType
			if (tempN <= turnOnTempN) {
			} else if (tempN >= turnOffTempN) {
	if (VT_Vent_Mode_Nursery.state == 3) {
		var Number turnOnTempN = setpointN + 0.5
		var Number turnOffTempN = setpointN - 1.5
			if (tempN >= turnOnTempN) {
			} else if (tempN <= turnOffTempN) {
end
rule "Nursery Vent Control"
when
	Item FF_Nursery_Vents changed
then
		if (FF_Nursery_Vents.state == ON){
			FF_Nursery_Vent.sendCommand(ON)
		} else if (FF_Nursery_Vents.state == OFF) {
			FF_Nursery_Vent.sendCommand(OFF)
end
rule "Nursery Use Furnace"
when
	Item VT_Nursery_Keepwarm changed or
	Item Nursery_Temperature changed or
then
	if (VT_Nursery_Keepwarm.state == 1 && VT_Vent_Mode_Nursery.state == 2) {
			postUpdate(NurseryNeedHeat,1)
			postUpdate(NurseryNeedHeat,0)
	if (VT_Vent_Mode_Nursery.state == 0 || VT_Vent_Mode_Nursery.state == 1 || VT_Vent_Mode_Nursery.state == 3) {
end
sitemap
	Text label="Nursery" icon="baby_1"{
        		Frame {
        		Switch item=VT_Vent_Mode_Nursery label="Vent Control" mappings=[0="Off", 1="On", 2="Heat", 3="Cool"]
				Setpoint item=VT_Vent_Setpoint_Nursery label="Target Temperature [%.1f °F]" minValue=65 maxValue=80 step=0.5 visibility=[VT_Vent_Mode_Nursery==2, VT_Vent_Mode_Nursery==3] icon="heating-60"
				Text item=FF_Nursery_Vent
				Text item=Nursery_Temperature
				Switch item=VT_Nursery_Keepwarm label="Use Furnace?"	mappings=[0="Off", 1="On"]
				Switch item=VT_Nursery_Keepcool label="User AC?"		mappings=[0="Off", 1="On"]
				Text item=Nursery_Volts icon="battery-90"
				Chart item=Nursery_Temperature period=4h refresh=300
				Chart item=Nursery_Volts period=D refresh=300
The reason i have a Vent and Vents item is one is virtual and i only want it to send a command to the actual ESP when the virtual *changes*
I don't want actuating the motor for no reason
