Page 10 of 10
Re: Serial MCU controlled relay/switch
Posted: 28 Sep 2021, 17:02
by Dondolo
The build you flashed is for 4M flash, so not really strange to see it won't boot.
Currently there is no pre-build file for 1M using that plugin.
So we have to make a custom build for it.
What else do you need in that build?
yes that's right, are just 1MB.
It would be nice if the custom build the standard of
ESP_Easy_mega_20210802_normal_ESP8266_1M.bin
contains.
If that is enough from the amount of memory.
Dondolo
Posted: 30 Sep 2021, 20:45
by Dondolo
Hi Td-ler,
do you find the time to create a customer version for the ESP01?
Greetings Dondolo
Posted: 30 Sep 2021, 21:55
Dondolo wrote: ↑30 Sep 2021, 20:45
Hi Td-ler,
Greetings Dondolo
Sorry had missed your post, or at least not placed it on my mental todo list.
Here you are:
https://www.dropbox.com/s/vtltocbc96p6f ... M.bin?dl=0
Posted: 30 Sep 2021, 22:23
by Dondolo
Here you are:
thank you very much.
I flashed it right away and it works wonderfully.
I will test tomorrow.
Thank you Dondolo
Posted: 02 Oct 2021, 14:23
by Dondolo
Here you are:
Unfortunately I cannot switch the relay.
I use the following relay
https://cdn.shopify.com/s/files/1/1509/ ... 1614874417
The Arduino code according to
on
byte open [] = {0xA0, 0x01, 0x00, 0xA1};
Serial.write (open, sizeof (open));
off
byte close [] = {0xA0, 0x01, 0x01, 0xA2};
Serial.write (close, sizeof (close));
Does it even work with the "Serial MCU controlled switch" plug-in?
Posted: 21 Oct 2021, 13:47
by enesbcs
Dondolo wrote: ↑02 Oct 2021, 14:23
on
off
Yes, this is the standard LCTECH command sequence, it is contained in this plugin. If you choose LCTECH, selected the correct baud rate, enable serial in ESPEasy settings, and disable serial logging, it should work. There were a bad batch which needs "Use IPD preamble" option. There were also a faulty batch which needs "command doubling" option to work.
Also there are several pieces of these LCTECH relays which are not original (clones) and even the other chip onboard is not programmed, so it can not be controlled by the ESP, does not matter, which firmware you use. And if it is not enough there are also some faulty ones, which has a power supply inadequate to even power on the relay.
Not to mention soldering issues.
So although it is a very challenging and interesting game to try to make them work, but i will never buy from this kind of device.
Posted: 22 Jun 2022, 11:04
by anton.tkachenko
Hello colleagues,
Is it possible to get status of "Serial MCU controlled relay/switch" via http get request? For example, for gpio-controlled relay it looks like
http://192.168.1.1/control?cmd=status,gpio,0.
Also is it possible to pulse such relay (turn on for a defined time)?
http://192.168.1.1/control?cmd=Pulse,14,1,500
All is according to
https://www.letscontrolit.com/wiki/inde ... _Reference
Posted: 22 Jun 2022, 11:11
by Ath
There is some documentation, though not very elaborate, on that plugin in the new (preferred and regularly updated) ReadTheDocs site:
https://espeasy.readthedocs.io/en/lates ... #p091-page
Posted: 29 Jun 2022, 07:06
by _Cyber_
the status is possible with:
http://192.168.10.244/json?view=sensorupdate&tasknr=1
pulsing the relay (at least with longpulse) currently does only work with the firmware attached in this forum thread.
it does not work with the released testing firmware - see
https://github.com/letscontrolit/ESPEasy/issues/3385
Posted: 29 Jun 2022, 09:29
As linked in the previous post, this is (apparently) an still open issue which slipped my attention (again...)
You can however time these things using rules
A bit of pseudo code, as I have not looked at the exact syntax of the plugin switch on and off commands.
N.B. you need to include the switch on and off commands yourself at the places where it is noted to do so.
on serSwitchPulse do
// here command to turn the switch on
timerSet_ms,1,%eventvalue1|100% // Set timer #1 for the given nr of msec, or default 100 msec when no eventvalue given
// here command to turn the switch off
Then you call this via an event called serSwitchPulse, with an optional argument to set the pulse duration.
