Rules on Mega version v2.0.0 2017-06-05 need some help
Posted: 22 Jun 2017, 22:36
by Henry
The Setup
Relay on 12
LED on 13
Dummy device on task 12
Push butom active low on task 1 as sw_1#Switch1
When push buttom is push once, timerset,1 is set to wait for next press, and Dum#Sw is set to the number of presses. After timeout in Rules#Timer=1 the action is run as per Dum#Sw
Give me a push buttom with multiple run options
The following used to work on EspEasy R146, R148, but on Mega only the first press is run.
I also try it when i use the new feature of timerSet,1,0 to disable the timer before i set it again, but no luck.
Can someone give me some help on the rules.
---Rule---
on switchoff do
gpio 12,0
gpio 13,1
inputswitchstate 0,0
on switchon do
gpio 12,1
gpio 13,0
inputswitchstate 0,1
on sw_1#Switch1 do
timerSet,1,3
gpio,13,1
delay,500
TaskValueSet 12,4,[Dum#Sw]+1
If [Dum#Sw]=1
Pulse,13,0,100
If [Dum#Sw]=2
Pulse,13,0,100
delay,300
Pulse,13,0,100
delay,500
gpio,13,1
On Rules#Timer=1 do
If [Dum#Sw]=1
event,switchon
if [Dum#Sw]=2
event,switchoff
Endif
TaskValueSet 12,4,0
Re: Rules on Mega version v2.0.0 2017-06-05 need some help
Posted: 30 Jun 2017, 14:03
by toffel969
I'm taking a bit of a wild guess here, but it won't harm to try it.
Your rules syntax looks ok, but the use of seperartor is inconsistent (space or comma) . Maybe there is a change in the way the rules are interpreted.
Try
on switchoff do
gpio,12,0
gpio,13,1
inputswitchstate,0,0
on switchon do
gpio,12,1
gpio,13,0
inputswitchstate,0,1
on sw_1#Switch1 do
timerSet,1,3
gpio,13,1
delay,500
TaskValueSet,12,4,[Dum#Sw]+1
If [Dum#Sw]=1
Pulse,13,0,100
If [Dum#Sw]=2
Pulse,13,0,100
delay,300
Pulse,13,0,100
delay,500
gpio,13,1
On Rules#Timer=1 do
If [Dum#Sw]=1
event,switchon
if [Dum#Sw]=2
event,switchoff
TaskValueSet,12,4,0
Posted: 30 Jun 2017, 14:09
by toffel969
An something else :
on sw_1#Switch1 do
Triggers every time that the switch changes its state, assuming a momentay push button connected between gpio and GND. So for one button press it should trigger twice.
From what I understand, this is not the behaviour you intented. As far as I understand, you want to register button presses.
Maybe try
on sw_1#Switch1=0 do
instead, as this rule will only trigger when the button once.
