EspEasy support Sonoff RF with 433MHZ control?
I bought a Sonoff RF. It is handy to have the built in RF control function. I wonder if by flashing EspEasy firmware, it can still support the RF control and setup as original way? If yes, it is good to know whether and how the RF control result can also be updated to Domoticz.
Tony
Tony
Re: EspEasy support Sonoff RF with 433MHZ control?
Hi.
Yes. There is such possibility.
1. You create in Devices two Switch input: Relay and Button.
2. In Rules you write a code:
on Button#Switch do
if [Relay#Switch]=0
gpio,12,1
gpio,12,0
Thanks for the feedback.
one more question: how to setup Button switch with which GPIO? I know if it is Sonoff basic, Button is set to GPIO0, but with this RF board, I don't know which GPIO the RF board is connected.
Tony
Tony
I think he wants to keep using the RF remote to switch on/off the relay no the button on the SONOFF itself... am I correct?
Correctly. With this method works the button on the Sonof and the RF remote.
Simultaneously. You can control the button. You can control the remote control.
So it works for me. Button + remote.
Thanks Aliki,this is what I want!
Is it still possible to pair a 433 remote with the sonoff and when ESP Easy is used?
Normally this done with 2 quick presses on the button.
Same question for disconnect the 433 remote with 3 buttons presses.
hello,
I take this topic up...
is there a special way to flash sonoff rf with espeasy ?
I have 10 to flash
thanks
I have 10 to flash
thanks
I would also like to know the paring process. I have so far been unsuccessful.
I have a Sonoff 4ch Pro with Espeasy Mega. I tried the 2 button press to pair. Not only does the remote not work, but that button no longer works locally either. Also, 3 button press does not restore the button to working.
G'day,
Has this problem been solved, where ESP_Easy can cohabitate with the RF remote control'
Tks.
Tks.
Users browsing this forum: No registered users and 48 guests
