I have a Fine Offset WH1080,WH1081(Proove WP1400) weatherstation with 868MHz sensor and that is not recognized by the RFlink gateway with a 868MHz transciever mounted. Other sensors are received.
Is this a known issue?
Fine Offset WH1080, WH1081 868MHz is not recognized?
Re: Fine Offset WH1080, WH1081 868MHz is not recognized?
It should work.. make a debug log and mail that to me.. frankzirrone@gmail.com
Ok, thanks!
I have sent you an email now!
Hi again!
I found some information about Fine Offset WH1080, WH1081. It seems like the have changed the protocol in 2012 from OOK modulation to FSK modulation in the protocol for the new units.
My unit is from 2007. Is OOK protocol supported by the RFLink 868MHz version?
What module are you using for receiving 868 MHz? CC1101? I have a WH 1090 which I think is very similar on the radio interface and would like to test thatWeatherOffset wrote: ↑05 Jul 2017, 09:26 I have a Fine Offset WH1080,WH1081(Proove WP1400) weatherstation with 868MHz sensor and that is not recognized by the RFlink gateway with a 868MHz transciever mounted. Other sensors are received.
- Jan
Jan Chrillesen, Denmark
RFlink supports the OOK version using an Aurel 868mhz transceiver
Ok, I'll give it a try.
I know a secret. Yeah, I'm not a professional gambler, but luck has nothing to do with me anymore. I think I should continue reading this in order to show up there next year.
