I'm trying to flash a sonoff basic with espeasy. I'm on a mac and using esptool.py. Here is my command:
esptool.py --port /dev/cu.usbserial-DN02TBMK write_flash 0x1000 ESPEasy_R120_1024.bin
It seems to work:
esptool.py v2.0
Connecting....
Detecting chip type... ESP8266
Chip is ESP8266
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Auto-detected Flash size: 1MB
Compressed 411264 bytes to 278756...
Wrote 411264 bytes (278756 compressed) at 0x00001000 in 24.9 seconds (effective 132.4 kbit/s)...
Hash of data verified.
Leaving...
Hard resetting...
After this nothing seems to work though. I have tried rebooting it again by pulling out the usb and putting it in again and also re-flashing it. But the led is not flashing and I can't see the wifi esp0 or any other new wifi for that matter.
Can I somehow tell where things went wrong? Should the led flash? What might cause this problem?
How can I verify that the flashing worked as expected?
Re: How can I verify that the flashing worked as expected?
Tried to monitor the serial port?
