I would like to use a push button to toggle a relay based on GPIO condition.
Could someone help me?
I am not sure the proper way in rules to check status of GPIO.
On Pushbutton=1 do
if GPIO13 is 1
then
set GPIO13=0
set GPIO13=1
Pushbutton toggle
Re: Pushbutton toggle
Please post your page with devices.
I suspect you need to do something like this:
Have you studied the wiki at all?
On pushbutton#state do
if pushbutton#state=1
GPIO,13,0
GPIO,13,1
I have looked at the wiki, i think
.. could you send me link?
I am using a Nodemcu Wemos D1.
i have a pushbutton connected between - and D2
relay connected from D7 -> Led -> inputrelay
the code you suggested always just preforms the first part of the statement
I would like to push the button and if the relay is already high then send it low and vise versa.
it´s so easy
in another Thread i find the solution, here are a rule for a modified (LED in red working on GPIO12) sonoff Basic:
Thing we should include it
(the choice =toggle) to the wiki
U had to create a device switch input with name Button, Valuename Switch on GPIO0 and
also one with name Steckdose, Valuename Switch on GPIO12.
best wishes
BerndJ
On Button#Switch=toggle do
if [Steckdose#Switch]=0
gpio,12,1
gpio,12,0
EndOn
best wishes
BerndJ
Then you need to create a device for the relay. You find more on the wiki for the Sonoff Touch (link below).
if relay#state=1
GPIO,13,0
GPIO,13,1
PS. I forgot the "endif" in my first code.
