Button mqtt (espeasy) for turn ON sonoff on other place (SOLVED)
Posted: 27 Sep 2017, 22:39
by r16
Hello friends, i started a new Project in my home.
I use that scheme;
and my configuration sonoff is:
but i have a problem inside of portal esp8266, anyone knows how configure that?
my goal is when I press the esp8266 button, the sonoff switches on, and when I click again the sonoff switches off.
Re: Button mqtt (espeasy) for turn ON sonoff on other place
Posted: 28 Sep 2017, 02:28
by r16
Posted: 28 Sep 2017, 06:15
by grovkillen
Only float is possible to use in the rules arithmetic tests. Please study the rule tutorial section in the wiki. Your syntax are generally wrong.
Posted: 28 Sep 2017, 11:08
by vader
1. The scheme shows button connected to RST, not GPIO0 (I assume you know that...)
2. Switch button type must be "Push Button Active Low"
3. The Sonoffs have the relay on GPIO12 (LED on GPIO13, reversed logic!)
4. Change the value name of the switch from "power" to "state", like in the rule used
5. "endif" is missing in the rules (I don't know if this is important?)
6. Only 0 and 1 as value are allowed in the rules for a switch device
Use the "SendTo" command to switch ON/OFF a device connected to another Sonoff unit (Global Sync enabled), or use the "Publish" command for MQTT...
Now it should work....
Posted: 29 Sep 2017, 01:07
by r16
@vader
hello again, ok..... i installed ESPEASY on my two devices.
----------------------------DEVICE 1----------------------------------------
**device is nodemcu with relay.With name sonoff1**
_the config is:_
_rule:_
**i defined UDP 65432**
this device i want control via HA and button of my esp.
Result with that rule:
HA control - OK
button ESP01- NOT OK
........................................DEVICE 2........................
**device is ESP01 with press button.With name sonoff2**
_the config is:_
_rule:_
this device i want when i press button the device 1 TURN ON when presse again device 1 TURN OFF
the state of button changes - OK
Device 1 not happens nothing.
where is the problem ?
Posted: 29 Sep 2017, 08:58
by grovkillen
On device one you should switch the 0 with 1 (but you don't need a device for setting the relay, if you don't want to, since relays are operated using the GPIO command):
on relay#state do
if [relay#state]=1
GPIO,12,0
GPIO,12,1
On device two you should publish a "cmd" command. See
wiki!
on button#state do
if [button#state]=0
Publish /sonoff1/cmd,GPIO,12,0
Publish /sonoff1/cmd,GPIO,12,1
Given that the device one is subscribing to the "
/sonoff1/#" on the FIRST controller. (Though the correct setting would state "
/%sysname%/#", see
wiki!)
You should not care about the GPIO-0 and try to set it to HIGH or LOW. This is not something you do since the microcontroller only alternates between 1/0 upon a toggle of the button.
Posted: 29 Sep 2017, 09:05
by vader
Set both Sonoffs --> "1st GPIO = GPIO0"
Switch Button Type --> "Switch Button Active Low"
In Sonoff2 remove GPIO0 setting in the rules
Check the MQTT communication in the logs
Posted: 29 Sep 2017, 19:47
by r16
grovkillen wrote: ↑29 Sep 2017, 08:58
on relay#state do
if [relay#state]=1
GPIO,12,0
GPIO,12,1
wiki!
on button#state do
if [button#state]=0
Now it Works.
thank youuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu
Posted: 29 Sep 2017, 19:58
by vader
Because the button of the Sonoffs is connected to GPIO-0. The relay does not need an entry in the device/task list. Only a switch with GPIO-0 for turning on/off the relay over a rule and GPIO-12. LED on GPIO-13...
Posted: 29 Sep 2017, 20:35
by r16
vader wrote: ↑29 Sep 2017, 19:58
you dont read what i wrote.
i dont have sonoff´s
my device are:
1. esp8266-01
2. nodemcu v3
Posted: 29 Sep 2017, 21:13
by grovkillen
Glad to have helped
Posted: 29 Sep 2017, 22:17
by r16
@grovkillen
now i have other problem.
The button Works fine, when i press it, the relay of device 2 changes from on to off and vice versa.
but when i click on button throught HOME ASSISTANT, the status of relay changes, but if i press the button of the device 1... it doesn´t Work.
did you have a home assistant?
rule device 1:
on button#state do
if [button#state]=0
rule device 2:
no rules
Posted: 30 Sep 2017, 14:23
by grovkillen
This happens because the "button" didn't know that Home Assistant has switched the relay. To fix this you might use many different techniques MQTT Import being my favorite.
On the relay device you can I publish a topic with a 1 or 0 when the relay is switched. Let MQTT Import sniff that topic and set task value of the button accordingly.
Posted: 01 Oct 2017, 05:06
by r16
grovkillen wrote: ↑30 Sep 2017, 14:23
What are you saying is:
on my device (sonoff2) where i have a button
put the rule:
on button#state do
if [button#state]=0
Publish /sonoff3/cmd,GPIO,12,0
Publish /sonoff3/cmd,GPIO,12,1
and other device (sonoff3) create something like this?
and create that rule:
on mqtt_import#GPIO0 do
if [mqtt_import#GPIO0] = 1
gpio,12,1
gpio,12,0
is this? i am trying but i am very confused.
Posted: 02 Oct 2017, 09:45
by grovkillen
Sorry for not getting back to you until now.
What you need is this rule on the
relay device:
on relay#state do
if [relay#state]=1
GPIO,12,0
Publish /sonoff1/RelayStatus,0
GPIO,12,1
Publish /sonoff1/RelayStatus,1
And on the
button device (and set up the MQTT Import to listen to "/sonoff1/RelayStatus"):
on button#state do
if [button#state]=0
TaskValueSet 2,1,1 //Given that the switch device is on TaskNr 2...
TaskValueSet 2,1,0 //Given that the switch device is on TaskNr 2...
Please observe that I have not tested this in practice. You may test and see if it works. Please feel free to come back
Posted: 02 Oct 2017, 13:14
by r16
grovkillen wrote: ↑02 Oct 2017, 09:45
relay device:
on relay#state do
if [relay#state]=1
GPIO,12,0
GPIO,12,1
And on the
on button#state do
if [button#state]=0
hello friend with that configuration. my relay always on off on off on off... and not stop.
i tried to change this:
on relay#state do
if [relay#state]=1
GPIO,12,0
GPIO,12,1
for this:
on relay#state do
if [relay#state]=1
GPIO,12,1
GPIO,12,0
but does not work too
Posted: 03 Oct 2017, 08:49
by grovkillen
Oooh, sorry about that!
We need to use a counter (check value) since the TaskValueSet will trigger the button#state over and over again.
on System#Boot do
Delay,5000 //Just to be sure...
TaskValueSet 3,1,0 //Just to be sure...
on button#state do
if [button#state]=0
TaskValueSet 3,1,1 //Given that a Dummy device is on TaskNr 3...
Event EventTriggerButton1
Event EventTriggerButton0
if [mqtt_import#GPIO0]=1
on EventTriggerButton1 do
if [Dummy#Value]=1
TaskValueSet 3,1,0 //Set the check value to 0...
on EventTriggerButton0 do
if [Dummy#Value]=1
Posted: 03 Oct 2017, 11:05
by vader
And why don't you use the button with Global Sync enabled? So the state should be on all devices the same and you don't have the stress with complicate sync rules!?
Posted: 04 Oct 2017, 03:54
by r16
grovkillen wrote: ↑03 Oct 2017, 08:49
on System#Boot do
on button#state do
if [button#state]=0
if [Dummy#Value]=1
if [Dummy#Value]=1
I appreciate your persistence, but it does not work. I think I'm going to give up.
I never thought this was so complicated to do.
Posted: 04 Oct 2017, 03:55
by r16
vader wrote: ↑03 Oct 2017, 11:05
Please, Put here the steps I have to take.
Posted: 04 Oct 2017, 05:55
by grovkillen
r16 wrote: ↑04 Oct 2017, 03:54
on System#Boot do
on button#state do
if [button#state]=0
if [Dummy#Value]=1
if [Dummy#Value]=1
Please upload your device page so I can see what names and task numbers you use. It's not complicated just different to what you have done before. Learning is power, once you got this working you will understand how to do more stuff.
Posted: 04 Oct 2017, 12:18
by vader
Ooops, doesn't work. Work not for switches. Only sensor values....
Posted: 04 Oct 2017, 15:23
by r16
grovkillen wrote: ↑04 Oct 2017, 05:55
on System#Boot do
on button#state do
if [button#state]=0
if [Dummy#Value]=1
if [Dummy#Value]=1
on my sonoff1 i have this rule:
on relay#state do
if [relay#state]=1
GPIO,12,1
GPIO,12,0
on my sonoff2 (buttoN) i have this rule:
on System#Boot do
on button#state do
if [button#state]=0
if [Dummy#Value]=1
if [Dummy#Value]=1
that is my config on sonoff2:
with this configuration..my button not Works..
and the relay status not change.
Posted: 04 Oct 2017, 18:09
by vader
Try this:
Make sonoff1 = Unit Number 1 (see Config page)
Make sonoff2 = Unit Number 2
On sonoff2 rule:
on button#state do
if [button#state]=0
SendTo 1,gpio,12,0
SendTo 1,gpio,12,1
Posted: 04 Oct 2017, 18:16
by r16
vader wrote: ↑04 Oct 2017, 18:09
Try this:
On sonoff2 rule:
on button#state do
if [button#state]=0
SendTo 1,gpio,12,0
SendTo 1,gpio,12,1
I already tried.
But the problem is;
If i press button relay of sonoff1 turn on.
But if i turn off relay through Home assistant, and press again button...the relay not turn on again.
Because button dont knows the state of sonoff1.do you undestand?
Posted: 04 Oct 2017, 18:28
by vader
Ah,ok. I know that problem (had the same with Domoticz). I had to press the button twice to be in sync again with the relay on other device.
Change the rule on sonoff1 in:
on relay#state do
if [relay#state]=1
GPIO,12,1
SendTo 2,inputswitchstate 0,1
GPIO,12,0
SendTo 2,inputswitchstate 0,0
So it inform sonoff2 to change the button state. And I found this:
on button#state do
if [button#state]=0
--> TaskValueSet 3,1,
Shouldn't it be 0? And task #3 does not exist!
It's all just a kind of logic puzzle...
Posted: 04 Oct 2017, 21:18
by r16
vader wrote: ↑04 Oct 2017, 18:28
on relay#state do
if [relay#state]=1
GPIO,12,1
GPIO,12,0
Now.
WORKS LIKE A CHARM
sooooo easy, thank you @Vader and grovkillen for all persistence.
Perfect.
Now i can make this:
https://www.youtube.com/watch?v=ImVK5cGVrpQ&t=1s
Posted: 04 Oct 2017, 21:28
by vader
No problem. You are welcome.
I know this, because I have all the crap already behind me....
Posted: 04 Oct 2017, 21:30
by grovkillen
Sorry for not giving you the correct rules (didn't know your setup etc.). But glad you got it to work!!
