How to pair milight FUT103 GU10 RGB+CCT
Posted: 13 Oct 2017, 21:37
I try to pair a Milight FUT103 via RFLink, unsuccessful sofar.
RFLink works as when I create a device in domoticz by learning via Zone control or iBOX I can control te bulp.
However if I try to pair it directly I cannot:
I tried per instructions for this bulp:
10;MiLightv1;20F746;01;34BC;PAIR;
Nothings happens, I then tried the commands which are not intended for this bulp and something happens with:
10;MiLightv1;F746;01;34BC;PAIR;
It flashes 2x green and the third time it becomes solid white. It does this for each other id I use, but then after I cannot do anything. No on/off, and also no UNPAIR.
Anyone already a FUT103 GU10 RGB+CCT device ?
Help is appreciated
Peter
Help is appreciated
Peter
