assign task value to a quad dummy device field
Posted: 15 Oct 2017, 05:02
I want to retrieve the WiFi level and assign this to one field of a quad dummy device. So i will set up a "sys info" task and un-tick the "send to controller" box. From my basic understanding i will then set up a rule that triggers once the "sys info" event has happened then assigns the WiFi level value to a dummy device using the "TaskValueSet" command.
Can someone help me out with the rule syntax to do this?
TIA
Ray
TIA
Ray
