Milight zones how do RFLink and zone controller relate
Posted: 16 Oct 2017, 20:31
Suppose I have a bulb paired in zone 1 with a milight zone controller.
How does this relate to pairing the same bulp directly via RFLink, when:
I set zone to 00
I set zone to 01
I set the zone to a number above 04, lets say 41
In other words can I make in domoticz a switch which controls a certain zone via the zone controller as well as a switch which does the same via RFLink. This would mean that the manual control is reflected in the other switch as well. I can do this when I learn the zonecontroller, but does it also work if I use the matching zone and pair manually, or do I miss the actual concept here. In addition I like to control each bulb also individually when needed, I think of doing this with a zone higher the 04 and with each an uniq ID, is this the right way ?
How many controls can be paired to a single bulp.?
I would like to use:
- zone controller
- iBOX
- Domoticz/RFLink zone (to control the bulp in a group)
- Domoticz/RFLink uniq ID (to control the bulp individually)
Thanks,
Peter
I set zone to 00
I set zone to 01
- zone controller
- iBOX
Thanks,
Peter
