Sonoff GPIO 14 keeps on switching, longer cable in wall to switch
Posted: 03 Nov 2017, 15:23
Hi there, I have a small Problem with the Control of my Sonoff. There are two external pushbutton switches connected to GPIO14.
The one closer to the sonoff is working without a problem. The Second one is about 4m away and uses existing wires through the wall. As sonn as I connect this switch the sonoff keeps switching on and off.
I guess this is due to some interference from power cables running in the same wall. Is there an easy way to fix this?
